Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Access Port
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 2, 2008, 03:23 PM   #16
CDO
Personal Sales Rating: (2)
Drives: 06 IX MR
My barometric pressure read 50 kPa. I reflashed and took her out and checked, it still read 50. As you may note, my reads in kPa, not % as you say yours reads. A % reading doesn't really make sense. But I have no idea if 50 kPa is correct.
I drove about 25 miles and saw a max. knock count of 4. That's lower than yesterday, so it's possible the reflash had something to do with the difference although driving circumstances may not have been identical.
Edited to add that my throttle position read 14% at idle, fully warmed. Don't remember what it used to read when I first got my AP.
Offline
Old Jun 3, 2008, 11:32 AM   #17
Personal Sales Rating: (0)
Drives: '99 E36 M3
Hello Gents,
The AP beta firmware has been rev'ed. Long/Short Term Fuel Trims have been fixed. EGR and Barometric Pressure have been removed at the request of customers due to confusion. To my knowledge the Knock Sum Live Data parameter is functioning as it should. I will address concerns in another post.
Please follow the link. The AP-MIT-001.exe has been updated.
Thanks,
Rob
__________________
Rob (at) Cobbtuning (dot) com
Enginerd
www.cobbtuning.com
Offline
Old Jun 3, 2008, 11:37 AM   #18
Drives: '99 E36 M3
Knock sum movement is going to happen with the seasonal change into warmer weather. It's ok to see bumps into the 4-7 range. I would be a little more concerned about anything above 10. If you have manual boost controllers, you may have to turn the boost down a touch when the weather gets hot or run a little higher octane.
If the knock sum becomes an issue, we will be more than happy to address the tune of our maps. At this point we are confident our maps will be safe even in the hot weather.
Thanks,
Rob
__________________
Enginerd
www.cobbtuning.com
Offline
Old Jun 3, 2008, 12:13 PM   #19
CDO
Drives: 06 IX MR
Quote:
Thanks,
Rob
You have to be kidding. Someone complained they didn't understand it so you removed them? Why not just explain them?
I don't think we have any control over barometric pressure, but knowing the exhaust temp could be helpful/interesting.
Also, as long as you're adding/subtracting things, could you bring back intake temp? I used that to see what the outside temp was.
Offline
Old Jun 3, 2008, 12:31 PM   #20
Drives: '99 E36 M3
Quote:
Sure, I'll put the EGR back in for the release version.
__________________
Enginerd
www.cobbtuning.com
Offline
Old Jun 3, 2008, 12:43 PM   #21
CDO
Drives: 06 IX MR
Thanks.
Offline
Old Jun 3, 2008, 12:44 PM   #22
Personal Sales Rating: (1)
Drives: 2006 GG Evolution IX GSR
Rob,
I agree with the above statement....if you could put back in the Intake Temp that would be awesome...I like to see what that is so i figure I can subtract 15-20 degrees and that should give me the outside air temp.
Please just don't take out the Knock Sum.....I live everyday for that reading
Offline
Old Jun 3, 2008, 12:47 PM   #23
Hello Gents,
Thanks,
Rob
Rob,
Is this the fix based on the trial run from yesterday that I responded to you about this morning?
Offline
Old Jun 3, 2008, 01:09 PM   #24
Personal Sales Rating: (4)
razorlab's Avatar
Drives: a laptop connected to your ECU.
EGR is not EGT, FYI.
The EGR thing is reading your exhaust temp. A very high temp reading means you're about ready to melt some holes in your piston(s).
Again, EGR is not EGT so this statement is incorrect. Evo's do not have a EGT sensor from the factory. EGR is a emissions device that is on the intake manifold and is not used for tuning in the same regard as EGT. A EGT sensor is usually installed on the exhaust manifold to read the exhaust temp coming out of the head exhaust ports.
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Jun 3, 2008, 09:40 PM   #25
CDO
Drives: 06 IX MR
Quote:
You're right. I was thinking EGT. But isn't the EGR reading a temperature?
Nevermind on the question. While fixing myself a bowl of Cheerios I remembered that the EGR has to do with recirculating exhaust back into the engine for emissions reasons or something like that.
Offline
Old Jun 3, 2008, 10:13 PM   #26
razorlab's Avatar
Y
Correct and it does not operate at idle or WOT, only cruise.
__________________
E85 Army
Offline
Old Jun 3, 2008, 10:18 PM   #27
SCEvol8's Avatar
Drives: 2003 Evo 8, 277 awhp, 262 torque @ 21.9 psi
Thanks,
Rob
I agree that knock sums can change depending on season....just as different fuels can sometimes affect it. The thing is, I am running the exact same octane, exact same fuel, exact same fill up station, nearly identical temperatures, and no adjustment made to the boost controller from the day I had my car tuned at GST. In fact, as previously stated, I was not even in boost when my AP said my car had a knock of 22. I was cruising at about 60mph....not accelerating at all. Ever since my tune, my AP has NEVER indicated a knock count higher than 3 and that was when the car was cold. The only time I ever had a knock count that high was when I tried running the off-the-shelf stage 2 91 octane map and it said I had a knock count of 10. Sorry, but I honestly don't believe my car threw a knock count of 22, especially since same conditions, same driving style, same gas, same speeds produced no knock count prior to the update.
__________________
Tanabe GF210 springs
HKS 272/272
Megan DP
HKS Cat-Back exhaust
stock cat
AEM Intake
Walbro 255
RC Engineering 660cc injectors
Hallman MBC
Cobb Stage 2 protune by GST
My Stereo:
http://www.lotts.com/2003MitsubishiLancerEvo8.htm
Offline
Old Jun 3, 2008, 10:20 PM   #28
Personal Sales Rating: (23)
Drives: Boosted 2.0
Send a message via MSN to ~BoOsTeR~
Could you bring back MPH?
Anyways - my experience as follows -
Baro @ %50, doesn't change
LIFT/STFT @ %25, doesn't change
Also target idle is @ 796, doesn't change
Knock from 0 - 10, definitely sensitive to atmospheric conditions - it's cool, it knocks less. Most of the time not at all. Previously knocked from 0 - 6, most of the time it never knocked above 2, unless it was hot out. The way I percieve it to be so far (and my senses may just be fooling me..) is that the variable knock frequency counter, along with the higher readings seem to indicate a more sensitive calibration. Maybe the intial calibration for the Knocksum was a little off?
Not sure, but that's the way I percieve it.
Offline
Old Jun 4, 2008, 12:15 AM   #29
Drives: EVO 9
updated the ap and for some reason i cannot reflash to any maps. does anyone have any problems with reflashing? whenever the map shows the uploading within the second of that loading bar pop up it says i need to check my connection blahblahblah. i've check double check even triple check everything knowing forsure i didn't unplug the usb or the DL connector. never had this prob til this update.
new look is ok but i prefer the old look cauz the new look is like the wrx's/sti, meter n needle more awesome. plz bring back all the other features in the live data that was not in this updated version on the next update.
Offline
Old Jun 4, 2008, 12:24 AM   #30
CDO
Drives: 06 IX MR
Thanks, and I forgot to say thanks for correcting me.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
