Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Access Port
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 6, 2008, 02:37 PM   #1
Personal Sales Rating: (0)
SCEvol8's Avatar
Drives: 2003 Evo 8, 277 awhp, 262 torque @ 21.9 psi
max number of reflashes?
Sorry, I tried searching but couldn't find an answer. I have a Cobb accessport and it has an anti theft option that can be flashed to the ecu. Problem is I may be flashing to the ecu as much as 10 times a day if I use it. Will this be a problem?
Offline
Old Mar 6, 2008, 02:38 PM   #2
EvoM Super Moderator
Personal Sales Rating: (91)
chaotichoax's Avatar
Drives: ix mr
Send a message via AIM to chaotichoax
moving to accessport section
__________________
Rules & Regulations
Photoshoots - 1 2 3 4 5 6
Flickr
Offline
Old Mar 7, 2008, 07:43 AM   #3
Personal Sales Rating: (1)
Drives: 2006 GG Evolution IX GSR
Quote:
I have no answer on how many times the ecu can be flashed. I've read a couple of threads regarding that..not related specifically to the AP..but I don't think it matters....some people have said they have flashed the ecu hundreds and hundreds of times.....
in your case though if the theft thing is such a major concern...as I feel with this car it is...why don't you just pull out your fuse then...by doing that you could even put your key into the ignition and it still won't turn over....the only way anyone could ever steal the car is if they loaded it onto a trailer, towtruck etc.
That's what I do
Offline
Old Mar 7, 2008, 09:36 AM   #4
CDO
Personal Sales Rating: (2)
Drives: 06 IX MR
That sounds like a lot of flashing. Up to 20 times a day (back and forth). Like CPA5 said, I've read of people doing it in the hundreds, but you'll end up doing it in the thousands. I don't know.
It's been so long since I used my AP so somebody please correct me if I'm wrong, but Realtime flashes take over 4 minutes to install and reflashes about 45 seconds. Add the time needed for picking the map from the menu and in the end I don't think the anti-theft flash is a very good option for you.
Offline
Old Mar 7, 2008, 12:20 PM   #5
SCEvol8's Avatar
I would just use it as an additional level of security over the alarm. Maybe I'll just add a switch for the fuel pump somewhere in the car
Offline
Old Mar 7, 2008, 12:23 PM   #6
Personal Sales Rating: (28)
Drives: 2003 apex silver EVO VIII
i have well over 1000 reflashes on my ecu and i havnt had a single problem yet..... i might even have closer to 2000 flashes
Offline
Old Mar 7, 2008, 02:21 PM   #7
Dude--just pull your fuse!!! It takes like 25 seconds to pull out and put back in....with the fuse pulled the only way to steal the car is load on a trailer, truck pull, etc.....which in that case anti-theft/fuel pump switch/etc. won't matter.
pull your fuse and then put your key in to start the car and watch it not turn over...it is by far the best protection....besides GOING INVISIBLE
Offline
Old Mar 7, 2008, 05:22 PM   #8
SCEvol8's Avatar
Which fuse do you pull? Sorry i'm at work so I can't see the fusebox right now
Offline
Old Mar 8, 2008, 09:18 PM   #9
I'm surprised no one has (can) answered this question for you yet....I can't be the only person with an evo doing this
Under the hood....there are two black box casings on the right hand side....one is square and bigger...you want to open the slim casing.....unless your car has different fuses then I do...there are three fuses in there....you pull out the one closest to the front of the car...it pulls right out.....to double check...pull that fuse and then go and start your car....unless it is diff. from my 9 then the car won't start.....and WALA.....it won't deter someone from smashing in the windows and stealing crap out of your car...but they won't be able to get in and drive off either
Offline
Old Mar 8, 2008, 10:30 PM   #10
Unless they have spare fuses on them
Offline
Old Mar 8, 2008, 10:59 PM   #11
CDO
Drives: 06 IX MR
You could be. I know I've never bothered doing anything like that.
Offline
Old Mar 9, 2008, 12:57 PM   #12
SCEvol8's Avatar
Alright, I'll check it once I get the car back. it's currently in the shop for about 3 weeks getting some toys installed....gonna suck driving Honda 'til then
Offline
Old May 9, 2008, 10:28 AM   #13
Personal Sales Rating: (3)
Drives: 06 EVO MR
Quote:
Or a flatbed. I've heard of that happening
__________________
Toyo Tires
I :heart: R888's
Offline
Old May 9, 2008, 10:30 AM   #14
Former Vendor
Personal Sales Rating: (5)
Drives: 03 Evolution VIII, WRX/Sti wagon
Send a message via AIM to IA Performance
if you are using the real time flash you shouldn't have an issue with using the anti theft but if your hard flashing then you may eventually wear out the ECU.
Offline
Old May 9, 2008, 11:08 AM   #15
TouringBubble's Avatar
Drives: IX MR SE
Send a message via AIM to TouringBubble
the ROM in the ECU should be good for way more than 10,000 flashes or so. I think most chips are rated as 100,000. Some of the ECUFlash guys have done several thousand w/o issues. I've personally flashed about 1200 times I'd guess.
__________________
My Sponsor House Profile | EPM | AMSOIL | GTWorx
"We two souls have shared a cheese sandwich more than twice!"
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
