Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Access Port
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 12, 2008, 03:18 PM   #16
Personal Sales Rating: (4)
razorlab's Avatar
Drives: a laptop connected to your ECU.
EvoJedi,
U haf PM.
__________________
Bryan - 05 MR - E85 and FPgreen powered
E85 Army
Offline
Old Feb 12, 2008, 03:35 PM   #17
EvoJedi77's Avatar
Drives: WW Evo 9 MR
Quote:
Originally Posted by razorlab View Post
EvoJedi,
U haf PM.
replied
Offline
Old Feb 13, 2008, 03:51 PM   #18
Personal Sales Rating: (1)
Drives: 2006 GG Evolution IX GSR
I'm glad Bryan is helping you out...he knows his stuff
By boost from gear to gear is different..which I'm told is normal....different gears have produce different loads which produce different boost spikes.
In 3rd,4th,5th...my boost peaks at around 21.5 to 23.3 psi (depends on how cold the weather is) at around 3500 rpm and that lasts only till about 3900-4000 rpm when it tapers off to around 19-18psi.
hope that helps
Offline
Old Feb 13, 2008, 05:02 PM   #19
EvoJedi77's Avatar
Drives: WW Evo 9 MR
hope that helps
Ya hes a real chill guy. What map are you running again?
Offline
Old Feb 13, 2008, 11:00 PM   #20
Personal Sales Rating: (2)
Drives: around
Send a message via AIM to skywestseth Send a message via MSN to skywestseth Send a message via Yahoo to skywestseth
If you are installing the test pipe this weekend then why are you running a stage 2 map now?...you did read in the notes that stage 2 map was for a TBE....that could be a problem...
Offline
Old Feb 13, 2008, 11:05 PM   #21
Personal Sales Rating: (0)
john151's Avatar
Drives: over to your mom's house when your dad is at work
Mine was tuned at Buschur by dave himself. Sweet a$$ tune. It even idles like a kitten with a 272 grind. If you dont mind road tripping to Ohio i would recommend it.
Offline
Old Feb 14, 2008, 07:01 AM   #22
EvoJedi77's Avatar
Drives: WW Evo 9 MR
Quote:
It didnt run any different (boost wise) before or after the test pipe, I had a high-flow cat in before
Quote:
That sounds pretty sweet, If only he were much closer..
But after some help from Razorlab I've gotten my boost peaking where it should be and holding relatively well around that range
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
