Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Access Port
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 7, 2008, 03:41 PM   #1
Personal Sales Rating: (12)
TheEvolutioner's Avatar
Drives: WW IX
Boost Spikes to 24-25 psi
I've notice sometimes only in low gear (2nd, 3rd, sometimes 4th) that my boost spikes to 24-25 PSI then shoots down to 20-21 PSI. On high gears, 5th and 6th the boost is on target, 22.5 psi then tapering to 21 psi. Any reason for this??? Has this happen to any one running stage 2 93 octane?
Thanks
Jason
Offline
Old Jan 8, 2008, 10:56 AM   #2
Silver Sponsor
Personal Sales Rating: (0)
Drives: 323 GTX
Give us a little more information if you would. What engine mods to you have on the car? What part of the country do you live in (i.e. what elevation are you at)?
Offline
Old Jan 8, 2008, 10:58 AM   #3
EvoM Moderator
MR Turco's Avatar
Drives: WW Evo IX w/ SSL/SE, 2000 Sentra SE w/ SR20
His location is queens so he should be at sea level. I would assume it is from the cold weather. 24-25 spikes should be ok on pump gas. I have never seen knock up to 24psi spikes.
__________________
-Mike
The Rules - love them
TephraMOD V7 - now serving 25x30 fuel and timing maps and Gear Dependent Boost Control
Quote:
Originally Posted by beavis820 View Post
turco is a damn fine mechanic without me
Online
Old Jan 8, 2008, 11:04 AM   #4
Personal Sales Rating: (1)
Drives: 2006 GG Evolution IX GSR
Im running stg2/91oct .....tucson az...about 1800-2400 elevation
COBB TBE, Nisei ICPIPES, Okada Coils, WORKS filter
in 3rd/4th/5th I have been consistenly hitting above 21.5 psi....my gauge has the light come on at 22psi for warning....in those gears when at WOT it never stays below or on target...the highest reading so far from a couple weeks ago was 23.75psi.....from another thread ROB said this was okay.....and at wot I haven't ever seen any knock...maybe 1
BUT.........the other nite going up a little hill in fourth gear at around 3200 rpm at less than half throttle.....I pinged a 6 count on knock...WTF!!!!!!!!!!!!!
Should I be concerned about that?
IX Lives '08
Offline
Old Jan 8, 2008, 06:08 PM   #5
Drives: WW IX
Quote:
Chris, I am running the stage 2 93 octane with cobb TBE, cobb intake, megan O2 housing. I notice this about two days ago. 1st gear hit about 15psi then I shifted to 2nd, the boost spiked to 25psi then shooting down to 21psi and holding then I shifted to 3rd gear, boost spiked again to 24-25psi then quickly shooting down 21 and holding, then 4th, 5th and 6th gear is normal to 22.5 psi tapering to 20.5-21psi. It's fairly warm out for this time of year, about 60 degrees, but 2 days ago it was around 50 degrees. Could it be the weather changing so fast?
Offline
Old Jan 18, 2008, 06:04 AM   #6
turbo271's Avatar
Drives: 2004 WW EVO VIII (sold)
I got the AP a couple of days ago, and I have the same problem. I'm pretty sure that it is a boost leak. The trick is finding it.
I haven't seen any knock either, so no biggie. Just gotta fix the boost leak because sometimes it fluctuates down to about 17 psi and then back up to 21. but only at around 4000 rpm.
__________________
9.8 / AP/ Skunk2 CB & TP / TurboXS DP / HKS RS Intake / HKS SSQV BOV ver2 / Homemade Recirculation kit / Swift Spec R springs / Cusco ver2 underbrace / Black OEM Enkeis / Broken Front Bumber - GHETTO!
Offline
Old Jan 21, 2008, 11:05 AM   #7
Drives: '99 E36 M3
IX Lives '08
You should be ok, but have Steve take a look at that area of load when you get ProTuned.
Thanks,
Rob
__________________
Rob (at) Cobbtuning (dot) com
Enginerd
www.cobbtuning.com
Offline
Old Jan 21, 2008, 11:16 AM   #8
Quote:
Thanks,
Rob
Rob--thanks for answering.....now that I get to view this knock stuff I must admit it has made me more paranoid .....im sure when the car was stock and I couldn't see that value it was worse.
Stephen is aware of this light load higher knock issue....I'm sure he'll be able to tweek here and there to make it better.
I hope to get tuned asap
Offline
Tags
98, evom, highest, psi
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
