How To: Replace Your FAST Key Battery
Old Nov 14, 2011, 01:53 PM
DatRAzn's Avatar
So I got into my car the other day, and the ***** greeted me with a nice "KEY BATTERY LOW" message. Not wanting to get stranded because of a dead fob battery, I did some poking around to see what needed to be done. I didn't see anything related, so here's a quick write-up for you fellas (Yeah. I only said fellas, we all know girls don't exist on the internet).
What you need:
  • 1 - Set of hands (Ten fingers)
  • 1 - Flat head screwdriver
  • 1 - Replacement CR2032 battery (This can be found for $2.25 on Amazon)
  • 1 - 2 minutes of spare time
What you need to do:
  1. Remove the emergency key.
  2. Look at the BOTTOM of the key, there should be a little slit here. Use the flat head screwdriver and pop open the back cover.
  3. Notice the shiny battery being held down by two tabs. Directly on the other side of the tabs, there should be a "slot" where you can gently pry out the battery with same screwdriver.
  4. Remove new battery from packaging.
  5. Slide new battery in, it might take some finessing.
  6. Replace back cover and emergency key.
  7. Pat yourself on the back for not running to the dealer for such a simple (and cheap) task.
  8. Get yourself a beer and try to convince your significant other to have some sexy time.
Youtube video for reference:
Not my video, but it's just as helpful
http://www.youtube.com/watch?v=TQXmCFuXEHI
Old Nov 14, 2011, 03:24 PM
SudzRA's Avatar
Nice write-up! Some tips (as I have done a few of these). Be EXTRA gentle. The plastic is soft and scratches easily. Put a piece of masking tape on the screwdriver to avoid scratches.
Old Nov 14, 2011, 08:59 PM
xi
xi's Avatar
Also, if you're gonna replace one, replace the other. These things are always transmitting. Even if you don't use the spare.
Old Nov 15, 2011, 06:40 AM
DatRAzn's Avatar
For sure. At 2.xx per battery, you'd might as well replace both. You'll ensure that they'll start to die around the same time again to boot.
Old Dec 1, 2011, 03:52 PM
ralliartation's Avatar
Nice handy write up. But there are women on here. I myself is one. Show some respect.
Old Jan 19, 2012, 12:44 AM
toredefine's Avatar
Gotta bump this up! Thanks Dat! My battery is about to go out.
Old Jan 19, 2012, 04:23 AM
jkennedy293's Avatar
My low battery came on once about a week ago, but hasn't come on since.
Old Jan 19, 2012, 07:30 AM
Ranger's Robin
The_Shocker's Avatar
Yeah, show some respect to us car womens!
Great write up btw
DatRAzn's Avatar
No problem, bro-tato!
If I'm remembering correctly, mine did this too. After awhile it'll come back on, and complain every time you start your car up.
Old Jan 25, 2012, 12:34 PM
J_TREE's Avatar
Thanks for this information. I know I will need this in the future, good to know.
Old Jun 3, 2013, 10:13 AM
FASTER345's Avatar
That plastic is really soft! I even triple masked the tiny screwdriver! Had to twist the screwdriver in the tab to get it to open, and that put a little dent in it. The rest was easy. Had to push REALLY hard to get it to close afterwards. Cheers.
Green_Bandit
21
Sep 9, 2019 02:14 PM
GetFoxed
Jun 12, 2019 04:56 PM
GrannyShifting
Mar 21, 2017 05:25 PM
Krakker
Outlander Sport
Aug 24, 2014 06:57 PM
mrbkkt1
Jun 18, 2007 01:19 PM
Quick Reply: How To: Replace Your FAST Key Battery
