Request: Installing transmission temperature gauge
Can anyone help me on how to install a temp gauge for our transmission? I'm just not sure where I would plug or thread into.
basically, you need to figure out which gauge you're using and then get the appropriate adapter to use in place of one of the stock drain plugs (there are 3, look up the thread on SS-T fluid change). the stock plug thread is M16x1.5
for example, if you were using an AEM gauge which has 1/8"npt thread, you'd want to get you one of these: http://www.autometer.com/cat_accesso...il.aspx?vid=58
so just figure out what threading your gauge of choice has and find the appropriate adapter
2009, 2011, aem, custom, evo, gauge, gauges, guage, install, installing, lancer, ralliart, temp, temperature, transmission
