HOW TO: TPMS FIX with aftermarket / winter rims.
Thats why I got it wrong I am too old to remember
but... this guy says it doesnt work
https://www.evolutionm.net/forums/la...imate-faq.html
soo.. does it work? can more ppl pls confirm @__@
Pressurized to 36psi and had it in the car for 900+ kms, three weeks or so...I get the "service required" message with the TPMS symbol. Originally thought it was because a leak but spray tested it and checked pressure after two weeks and didn't leak any air, it just does not work.
Does not work for me.
-Taranis
If your canister is holding pressure and you're still getting the error, then I'm guessing we assumed incorrectly about the TPMS sensors.
Perhaps it measures the pressure DIFFERENCE between the atmosphere (0psi) and inside the tire (35psi)?
Also, I wonder where the receivers are located for the TPMS sensors. Maybe each sensor needs to be located closer to the wheel wells?
I got them removed since three of the sensors weren't sealing right after getting my tires changed (the tire shop didn't install the grommet under the nut correctly) so I just went to rubber valve stems. In fact right after I had them removed from the wheels, I got the "Service Required" instead of the "Tire Pressure Low" message.
So yes, in some way or another they interact differently than the other TPMS sensors that the pressurized canisters work for. If it helps, ours are the Siemens SE57770 sensors. The ones on the Lexus' and Toyotas are Pacifics.
okay I have a question I just bought for new rims, I am going ot take the tpms sensors out of the factory rims and put them into the aftermarket rims, would this work with on low tire pressure light? And these are already in sync wit hteh car so is reprograming really needed?
it is a re-seal kit that is supposed to be used every time you remove or swap out tpms sensors so they dont leak-down constantly like majinfajita experienced. it basically comes with a new metal seal ring and rubber seal insert, new valve core, new tpms retaining nut, and new valve stem cap. i think they sell for about 10 bucks a piece, but to save the headache of losing air, its worth it, imo
it all depends, but you should be fine without reprogramming. the one thing i very strongly recommend is go to the dealer, or an online source if oemmitsuparts or whomever has is, and get 4 of part number: 4250B169.
It was too bad Kal Tire is the only vendor in Western Canada for Nokian tires because they have some of the shoddiest service techs mounting and balancing tires otherwise I would have just gone to the reputable shop (Urban Expressions) I went to that removed the sensors for me.
Can anyone verify this before I tear out my sensors from my rims.
Many thanks,
NEWB
Did you check if this works? I have a feeling our sensors need to have the external part of the valve stem mounted outside the canister to read absolute atmospheric pressure and the internal part inside the canister to read the tire pressure.
Many thanks,
NEWB
Many thanks,
NEWB
NEWB
