HOW TO: K&N SRI for no more than $70.00
Old Dec 11, 2009, 01:52 PM
Jake26's Avatar
Well its no secret that you could do this on your own.. I just recently decided to do this after removing my k and n drop in filter, i decided to go k and n SRI
step 1.
go to advanced autoparts or autozone and pick up the 3" k&N cone filter for around $40.00.
Step 2.
Go on to the link below and place an order for part number 14 Pictured there.. **in ralliart the maf sensor housing is located on the box so you will have to pull everything out and just leave the tube that was connected to the airbox.
http://www.trademotion.com/partlocat...layCatalogid=0
step 3. When your EVO X maf sensor housing arrives insert the housing into the tube, it might require a little elbow grease, but it will go in it..
step 4. Install the maf sensor and k&N cone filter..
Finished product:
ORDER PART NUMBER 14
Old Dec 11, 2009, 02:29 PM
Taranis's Avatar
Nice write-up!
This would require a tune afterward right?
-Taranis
Old Dec 11, 2009, 02:57 PM
Jake26's Avatar
Originally Posted by Taranis
Nice write-up!
-Taranis
yes. I am already tuned for it yes it would. Although this is like getting ur intake but much cheaper!!
Old Dec 11, 2009, 03:00 PM
Taranis's Avatar
Yeah it looks like a nice and clean install. =)
-Taranis
Old Dec 12, 2009, 05:31 PM
boondoc's Avatar
Thanx jake. UR intake for half the price. You aren't experiencing any issues like the UR intake right?
Old Dec 12, 2009, 09:01 PM
Jake26's Avatar
what are the issues with UR intake? i have had it before but i sold it while back.. when i had it i had no issues
Old Dec 13, 2009, 05:17 AM
boondoc's Avatar
I could've sworn there was a thread here that someone had issues with it. I dunno maybe i'm losing it . Either way this is something i will look into doing .
Old Dec 13, 2009, 01:03 PM
Gibby860's Avatar
Jake,
what is your avg AFR?
Old Dec 13, 2009, 01:09 PM
Jake26's Avatar
Originally Posted by Gibby860
Jake,
thats my next thing on the list. test pipe and a/f gauge... i am thinking inovate ( Sp?)
last time i went on a dyno it was a dyno day, so they didnt even do a/f reading.. as soon as i get it done i will post all that info..
Old Dec 15, 2009, 05:58 PM
OniLancer's Avatar
You may not need a tune. I would imagine the EvoX maf housing is the same dimensions, therefore, the computer will put the right amount of air/fuel in... unlike the UR one. I could be wrong though, would need to check the A/F on a dyno or something to verify.
Old Dec 16, 2009, 06:40 AM
boondoc's Avatar
Good point. but yea the only way to officially kno is to check the a/f.
Old Dec 17, 2009, 09:19 AM
boondoc's Avatar
If anyone is curious. The part number is 1500A219 at the dealership. I ordered mine today, there is only one in the entire country and had to be special order so please be kind and let me get it, LOL. $40 after FL tax.
Old Dec 17, 2009, 11:07 AM
Psycho09RA's Avatar
I was going to order one through my dealership a few weeks ago, but decided not to. I guess I will let you get it.
Old Dec 17, 2009, 11:39 AM
lancer0220's Avatar
http://www.trademotion.com/partlocat...14&catalogid=2
about a 1.00 cheaper ships from texas. they are a real good dealership get stuff to me real fast.
this SHOULD NOT require a tune. Just because it LOOKS like UR's intake doesnt mean it IS the same.
TTP engineering stated
"We ADAMANTLY discourage the use any intake system with an enlarged MAF adapter section specifically designed to bypass unmetered air from the intake past the maf sensor."
IF The evo X maf adapter part IS the same diameter as the stock maf adapter on the Ralliarts intake box (im pretty sure it is) then you DONT need a tune. All the air that is entering the car is being metered properly and the cars can adjust the fuel trims accordingly, I THINK i read somewhere that the UR intake maf housing was .2"
A SRI like thsi is the equivalent of having a K&N drop in filter and leaving the stock snorkel off so that the airbox has an opening...i dont think you would need a tune for taking off the stock snorkel.
UNLESS YOU HAVE LOGGED YOUR A/F with this item on UNTUNED and you know FORSURE that the A/F was wayy to high dont say it DOES need a tune. Theres no reason to pass along information that is not entirely correct.
Old Dec 17, 2009, 11:51 AM
boondoc's Avatar
Thank you sir
Quick Reply: HOW TO: K&N SRI for no more than $70.00
