2014 Ralliart Speaker Install??
Old Jul 6, 2014, 09:02 AM
Bobster22388's Avatar
Question 2014 Ralliart Speaker Install??
I purchased a 2014 Ralliart this December and have been looking at upgrading the factory audio system. I have the NON-Navi touchscreen unit that doesn't have the fosgate system or anything special. Does anyone know what size speakers are in there and if the previous years would work with the '14?
Old Jul 11, 2014, 08:28 AM
Big Steve's Avatar
The speakers in the front and rear door should be 6.5". I would assume that the previous years speaker would work in the 2014's.
Old Jul 11, 2014, 09:55 AM
Veronica's Avatar
Fronts are 6.5 component (can fit up to 1" tweeter in the sail panel).
Research more - you have to get an adapter plate or cut/mod the old speaker to use as an adapter plate for the doors. Mitsu used 3 hole speakers and almost all aftermarket are 4 hole.
You can also get the Alpine 'universal fit' with a swiss-chees frame that you align with the holes that match...
Old Jul 12, 2014, 08:35 PM
Thanks guys. Only thing I wasn't sure about since it was the newest year if they changed anything.
Old Sep 6, 2014, 04:21 AM
dangina's Avatar
i just replaced the deck and rear speakers. the rears are also 6.5" i reused the oem housings by flipping the speaker over and stomping on the backside of the speaker, comes out easy then I just drilled out the holes where I needed them and used longer screws. works great and sounds better than the **** oem speakers
Old Sep 26, 2014, 03:40 PM
anthony_hernan's Avatar
Thanks for the posting this question I have same year car and was wondering the same thing.
dcevox
Apr 17, 2018 02:09 PM
rcb213
Nov 4, 2015 03:28 AM
rcb213
Sep 26, 2015 06:27 AM
Jcusco407
Mar 31, 2010 05:01 PM
RalliartStyle
11
Dec 17, 2003 07:05 AM
Quick Reply: 2014 Ralliart Speaker Install??
