Sep 30, 2009, 01:01 AM
Personal Sales Rating: ( 0)
Drives: 2009 Ralliart (RG)
Ultimate Racing catback install
Hey guys,
Im ordering my UR catback from Ultimate-racing.com tomorrow for my RA, with no mini muff or resonator, and i know it is 100% bolt on. Just wondering what tools i will need to actually bolt this bad boy on, also if a simple hydraulic jack will raise the car high enough to do the install. I'd really rather do it myself than take it to some place.
All help and advice appreciated as always.
_eric
Offline
Sep 30, 2009, 01:46 AM
Personal Sales Rating: ( 1)
Drives: 09 Ralliart
impact wrench or reverse ratcheting wrench. don't know about what size you would need as I don't have the exhaust.
__________________
09 Ralliart
Offline
Oct 1, 2009, 08:51 AM
Drives: 2009 RG Ralliart, 2010 WW Ralliart
Quote:
Originally Posted by DarkSoldier246
Hey guys,
_eric
First things first. When you order your catback system, make sure you order the gaskets with it. The catback doesn't come with gaskets. I think it's an extra $18.
Taking off stock exhaust
- You will need a jack and jackstands. I used 4 jackstands to get all 4 wheels off the ground so I had some room to work.
- To remove the bolts at the back of the cat you either need a 17mm or 19mm (can't remember which) socket, rachet, and a 3" extension.
- For the bolts back in front of the muffler assembly you need a 15mm socket
- You may also want some WD40 to spray the rubber exhaust hangers to ease getting the stock exhaust off
Putting UR Exhaust on
- When you order the UR exhaust with the gaskets they supply bolts and nuts. I also went to the hardware store and got lock washers for the bolts.
- You will only need a 17mm wrench and socket to bolt the new exhaust on. You may also need a 19mm socket for the two bolts at the back of the cat but I can't remember if these were 17mm or 19mm. It is a very easy system to install. If you have any other questions just let me know.
Tony
Offline
Oct 1, 2009, 08:56 AM
Drives: WW Evo X GSR
^ nice writeup.
i have turboback from UR, besides the DP its an easy install. bolts right up
Offline
Oct 1, 2009, 10:01 AM
Thanks for the awesome info Tony, I'll let you know how it goes!
-eric
Offline
Oct 1, 2009, 11:50 AM
Drives: 09 WW Lancer Ralliart
sorry to sound like a total noob but whats the difference between a tbe and a cbe
Offline
Oct 1, 2009, 12:08 PM
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Ralliart
Quote:
TBE is a turbo-back exhaust, replaces all the pipes from the turbo outlet to the tail pipes.
CBE is a cat-back exhaust, replaces all of the pipes behind the catalytic converter to the tail pipes.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Oct 1, 2009, 12:55 PM
thanks for the info  say I get the TBE will that eliminate the cat converter? because i believe its illegal in california if u take out ur cat converter
Offline
Oct 1, 2009, 01:14 PM
Personal Sales Rating: ( 5)
Drives: 09 Octane Blue Ralliart ...09 Lancer GTS(TOTALLED)
Instead of getting a test pipe, u can get a high-flow cat
__________________
2009 Octane Pearl Blue Ralliart
2009 Octane Pearl Blue Lancer GTS CVT S&S (R.I.P. 7/8/09)
Offline
Oct 1, 2009, 01:15 PM
Drives: 09RA - GG
You can get a high flow cat that will replace the restrictive stock one. Unless you opt to get a test pipe, you don't HAVE to get rid of the cat.
Brad beat me to it.
__________________
GTS + 'Roids = 09RA
Quote:
Originally Posted by IdriveRA
"is that an evo?"
"Nah it's just a RalliArt"
Offline
Oct 1, 2009, 01:32 PM
What is the best exhaust setup for more pw/tq. I would like something that does not change, or very little change to the exhaust. I hate having something loud that attracts attention. Thanks
Offline
Oct 1, 2009, 01:55 PM
Quote:
If you want more power and torque I would go turbo back. If you are looking for something to provide slightly more hp with minimal noise I would go with the Ultimate Racing catback with the resonated midpipe and mini-muffler. It's not much louder than stock and gives you a slightly deeper tone. I've tried all the UR combinations on my RA with my personal experience below.
1. UR standard catback system (w/straight midpipe)- Extremely loud and resonates through out the whole interior.
2. UR catback w/resonated midpipe- Still pretty loud and resonates through out the whole interior but not quite as bad.
3. UR catback w/straight midpipe and mini-muffler (My setup I used)- Nice deep tone but not obnoxious. Minimal noise inside car.
4. UR catback w/resonated midpipe and mini-muffler- Slightly louder than stock w/ a deeper tone. Very minimal noise inside car.
Offline
Oct 2, 2009, 06:16 AM
thanks for your input, greatly appreciated!
Offline
Oct 2, 2009, 08:29 AM
thats some really good info akj237, i was going to order the straight midpipe with nothing on it but maybe now i should consider the resonator
thanks all
Offline
Oct 6, 2009, 04:48 PM
Drives: 2009 Mitsubishi Lancer RalliArt
Just bought my 09 Ralliart and was looking for a good exhaust. I like the combinations.
Thanks, That some really good info
Offline
Tags
2009, cat, catback, hiflow, install, mid, muffler, pipe, racing, ralliart, rear, tools, ultimate  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
