Aug 9, 2009, 10:39 PM
Personal Sales Rating: ( 0)
Drives: 09' Ralliart
License Plate Install
Quick questoin for you RA owners like me out there. I just got my plate's waiting for my frames before i put them on. Anyways, i was going to mountfront plate in the middle and i see 2 very small pre-drilled little bump where screws would go.
My question is do i need anything special to drill into these and mountmy plate?ihope i dont have to just put two screws in and leave them like that, i feel like it would rattle out and potentially fall off from overtime shaking abuse you know?
Lemme know what you guys did if you can, Thanks a lot!!
Offline
Aug 10, 2009, 08:06 AM
Drives: 08 gts , 07 outlanderxls ,09 RA
the car should have come with two rubber/expandable nuts.
BUT.........if you feel you need to have a front plate....
......do yourself a favor..go to your dealer and order the evo-x bumper mount
it will cost about 35$ and maybe they will discount the price since you just bought the car.
........and........YES , it will work on the ralliart.
Offline
Aug 10, 2009, 05:54 PM
well yeah i need to have a front plate im prety sure in california its required by law. needs to be certain height from ground also ( like you cant leave in your interior dash ) you live in cali ou should know this. but ty
Offline
Aug 10, 2009, 06:10 PM
Drives: 2009 Mitsubishi Lancer Ralliart
the evo plate and the normal centre are about the same height
Offline
Aug 11, 2009, 09:26 AM
Quote:
i have been lucky and have not run a front plate since getting the RA (november)
i had the factory evo-x mount on my '08 gts. it looked good........
...........well , better than in the middle.
Offline
Aug 11, 2009, 10:33 AM
Drives: 09RA - GG
I think front plates look....strange when it's in the middle of the bumper on our RAs. Get a side-mount plate  . You don't necessarily have to drill holes in the bumper, just get some industrial strength mounting tape.
Offline
Aug 11, 2009, 08:57 PM
Drives: 09 Ralliart
U should try this:
http://www.youtube.com/watch?v=C1zIG...layer_embedded
It may sit a little low. but atleast u got it when u need it.
__________________
[X] AMS stage 2 Flash
[X] AMS Compact Batt Kit
[X] AMS Polished SRI
[X] AMS Cat Back Exhaust
[ ] AMS Front Mount Inter Cooler
[ ] AMS Upper IC pipes
[ ] AMS Evo VIII BOV
[ ] AMS Trans Cooler
Offline
Aug 19, 2009, 09:51 PM
Drives: 09 WW Ralliart
^what he said. and while youre there, ask the service writer to have it installed for you. they should do it for free if they're a decent group of guys seeing as how it literally takes two minutes to put on, and it saves you the headache (and heartache) of drilling into your bumper, let a trained professional do it for you
__________________
03 LB Lancer OZ: totalled 06-2005
09 WW Lancer Ralliart: bought 05-2009
Back in the saddle again...
Offline
Aug 23, 2009, 08:16 AM
Drives: 09 ralliart lancer
thats what i did. the dealer installed it for free for me. i love the evo mount
Offline
Oct 21, 2009, 09:38 AM
Drives: 09 ralliart
I had the bad luck of them telling me that they couldnt get the mount and so i told them to jst drill the holes so i could put the mount in and they obviously drilled them in the center now i have to figure out a way to cover the wholes and then side mount it
Offline
Oct 31, 2009, 07:55 PM
Drives: 2009 Mitsubishi Lancer Ralliart in Rotorglow Orange
I just got the Evo side mount myself, I have yet to install it (terrible weather in NY the past few days) I am hoping when I take my front plate off that the wholes they had to drill will not be extremely obvious. If anybody finds a good way to make it look good at least at a distance definitely post how!!
Offline
Oct 31, 2009, 09:05 PM
Drives: 2010 Octane Blue Ralliart
Quote:
Hole plugs. You can find them at most hardware stores in the screw/bolt/nut section. They should have a pretty big variety at somewhere like Lowes or Home Depot, so you will want to either just buy a bunch (they are pretty cheap) and try them all, or bring in one of your screws from the plate and try to find something that will match (or you could measure the hole). Either way it will probably be some trial and error to get the best looking ones. =)
-Taranis
Offline
Oct 31, 2009, 09:54 PM
holes/grommets are 1/2 inch in diameter. save you some headache, i hope, while you're out trying to find the right size plug at home depot or wherever. good luck, let us know what you find
__________________
Offline
Tags
09, california, evo, frame, front, install, installation, lancer, licence, license, mount, plate, plates, ralliart, side  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
