Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Ralliart How-To/Installations
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 19, 2009, 04:48 PM   #1
Personal Sales Rating: (0)
2009 Mitsubishi Lancer
Krimsin's Avatar
Drives: 09 Ralliart
Send a message via AIM to Krimsin
Request: removing trunk release button and window chrome trim.
Just looking for a little incite on how to remove the trunk release button and the chrome trim that runs along the bottom of the windows.
Offline
Old Jul 19, 2009, 06:41 PM   #2
Drives: 08 gts , 07 outlanderxls ,09 RA
i spent a lot of time trying to figure out a way to remove the chrome window trim.
could not figure a way with out possibly damaging the metal
i just ended up spraying them with plasti-dip in place.
inside the trunk lid , remove the inner cover. you will see the clip to remove the trunk release button.
Offline
Old Jul 19, 2009, 09:32 PM   #3
Krimsin's Avatar
Drives: 09 Ralliart
sounds like next weekend's project. thanks
Offline
Old Jul 20, 2009, 01:48 PM   #4
Personal Sales Rating: (6)
08Lancer89's Avatar
Drives: Wingless 2009 Wicked White RalliArt
I painted my trunk release to match.
__________________
Mike ,
Check Out My Cardomain Page!
http://www.cardomain.com/ride/3270122
AMS BRINGING YOU THE FASTEST RALLIARTS
Future
[ ] Drive to AMS Custom tune
[ ] AMS High flow Cat
[ ] AMS FMIC Kit
[ ] AMS Tranny cooler
Installed
[x] AMS stage 2 ECU Reflash
[x] AMS Mini Batt Kit
[x] AMS Polished SRI
[x] AMS BOV Upgrade kit
[x] AMS Boost Pill
[x] AMS Catback
[x] Boost Gauge
[x] RRM Drop Springs
Offline
Old Jul 20, 2009, 02:05 PM   #5
Personal Sales Rating: (11)
jRox's Avatar
Drives: Traded: WW 2008 Lancer GTS || Upgraded: WW 2009 Lancer Ralliart
Send a message via AIM to jRox
Found this in another thread:
Quote:
Originally Posted by LancerES09 View Post
To take the window strip off lower your window and look on the inside, you'll see a screw. Take that out and it pops off =]
__________________
////////// FS: DRL Bypass w/ Relay Harness
Offline
Old Jul 26, 2009, 01:50 PM   #6
gccruz's Avatar
Drives: 09 Ralliart
Just plasti diped my trunk realese. Very easy to remove! I'll post pics ASAP. maybe nit till Mon and Tuse. It takes 5 min to remove. The chrome ring is part of the button and cant be removed without damaging the realese.
__________________
[X] AMS stage 2 Flash
[X] AMS Compact Batt Kit
[X] AMS Polished SRI
[X] AMS Cat Back Exhaust
[ ] AMS Front Mount Inter Cooler
[ ] AMS Upper IC pipes
[ ] AMS Evo VIII BOV
[ ] AMS Trans Cooler
Offline
Old Jul 26, 2009, 07:00 PM   #7
gccruz's Avatar
Drives: 09 Ralliart
Here you go.
You will need: Flathead screwdriver, needle nose pliers, painters tape, and your choice of paint. I used Plasti Dip spray. you can buy at any Home Depot. ( I had to go to a few to find it instock) It will take 5 min or less to remove and a few hours to paint and dry.
First you will need to remove the 7 pins with a flathead screwdriver.
Next you will need to remove the clip that holds the trunk release in place with niddle nose pliers. pull towards the front of the car or up. depends what way you look at it.
Pull the trunk release out and then unplug from harness.
Then thats it just tape it and paint! take your time taping it off. The black button will be tough. I placed a piece of painers tape across the chrome covering the button. Then I cut around the button with a small xacto knife, but any balde will do. I did it twice to ensure that it was covered good. The chrome might be removeable with the 2 screws but i didn't try, just taped it. Paint in thin coats so it doesn't run. I did 6 thin coats.
Take your time to removing the tape as not to pull off the Plasti Dip.
The pics are from my iphone so i hope they look ok!
I also did the window trim. There is already a how to on this. still gotta do the trim on the front bumper.
__________________
Offline
Tags
2009, bottom, button, chrome, cover, evo, inside, lancer, lid, mitsubishi, ralliart, remove, trim, trunk, window
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
