Jun 17, 2009, 08:24 AM
Personal Sales Rating: ( 0)
Drives: 09' Ralliart
If you know the dimensional and material specs on it, you can get a whole bag of gaskets for free from McMaster as an "engineering sample" if you work for a company that has an account. Probably get some with even better properties than the original.
Offline
Jun 19, 2009, 03:45 PM
Drives: 04 silver evo SSL
Mitsubishi recommends a synthetic blend for the ralliarts, altho i personally would use a full synthetic. that being said, going from conventional to synthetic and back again is not going to be an issue since the recommended synthetic blend is a blend of conventional and synthetic. most dealers have gone to a synthetic blend (ask), and i know we charge about 37 bucks and some change for the blend, full synthetic, yeah, your looking at around 80 bucks unless you bring your own (which lots of people do). also, IMO the best filter to go with the car (provided its not a fully built race car, and if it is, you wouldnt be reading this) is the factory filter. generally runs between 7 and 8 bucks. car was designed to use that filter, might as well use it. just my .02
__________________
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee!!!!!
Offline
Jun 20, 2009, 11:51 AM
Drives: 09 WW Ralliart
Quote:
Originally Posted by rdc
Can anyone put up a picture of the drain plug gasket? I believe it's the same for the first gen RA. My problem is that when I went to pick one up at the local Mitsu auto parts, the guy looked it up and then gave me a regular washer saying that it was the gasket.
same crush washer as all the new model mitsu's use. why would he even look that up? not a very good parts guy if u ask me. MD050317 is the part number if he still is having issues.
as far as the filter question goes, you're better off going oem than anything else unless of course its full race application which, as said before, shouldnt need to read this thread. for the extra two bucks over aftermarket cost its worth it. besides, they come pre-lubricated. MZ690116 in case anyone wants this part no. also
__________________
03 LB Lancer OZ: totalled 06-2005
09 WW Lancer Ralliart: bought 05-2009
Back in the saddle again...
Offline
Jun 20, 2009, 08:35 PM
Personal Sales Rating: ( 3)
Drives: dodging potholes at an area near you
Quote:
IDK, I just thought that maybe it would be a washer made out of some kind of plastic or silicon so as to be used only once. Until then I never even thought of it being just any regular washer that I can even get at my local hardware store. Thanks for the part No.
Edit. I just saw a picture of the gasket and its nothing like what they gave me. I guess IŽll be paying some other parts store a visit from now on.
__________________
Quote:
Originally Posted by BLKRalliArt04
Man, my gf said she wasnt gonna get me anything for my car, says buying stuff for cars is stupid.
Quote:
Originally Posted by Myszkewicz
I got myself the RRM Piggyback for Xmas. Buying stuff for girlfriends is stupid. :lol:
04 R/A
PR = MIVEC Nation!!
Offline
Jul 8, 2009, 11:22 PM
Drives: 09 GG Lancer RA
I might need to get some of those ramps. I checked the manual ('09 Ralliart) and I may have missed where they indicate the recommended jacking points. All I can find refenced in the manual are the side jack points (for changing a flat tire with the rickety jack provided with the spare).
Does anyone know an acceptable front jacking point for a floor jack and jack stands (that won't crush and bend the underbody)?
How about the rear jack points as well for performing tire cross-rotation?
TIA
Offline
Aug 26, 2009, 05:10 PM
Drives: 06 Eclipse Gs, 09 Ralliart
Nice going to do this myself today
Offline
Sep 3, 2009, 03:44 PM
Drives: 09 Apex Silver Ralliart
fyi - my car takes nowhere near 5 quarts; fully drained it'll fill with a little over 4...anyone else note their fill amounts varying?
Offline
Sep 3, 2009, 04:46 PM
Drives: '09 WW Ralliart
TIA
I would like to know this too
Offline
Sep 4, 2009, 07:46 AM
Personal Sales Rating: ( 1)
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Ralliart
When jacking the front, I use the jacking point directly behind the front wheel well (there's two notches cut out in the rail there). I think that point is described in the manual, but it's been a while since I've looked.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Sep 4, 2009, 09:15 AM
That's the only points I saw in the manual. Notches on front and rear.
Offline
Sep 4, 2009, 09:22 AM
Drives: 2009 RG Ralliart, 2010 WW Ralliart
Quote:
If you jack anywhere along the rail you'll be fine.
Offline
Sep 4, 2009, 09:25 AM
Quote:
Are you changing the oil filter as well? If you're not changing the oil filter I could see it only taking about 4 1/2 quarts but if you are changing the oil and oil filter it definitely takes 5 quarts.
Offline
Sep 5, 2009, 07:00 PM
Quote:
1st change i did the filter too, let it drain bone dry and added 5 qts and the stick was reading over-filled as hell. gave it a couple days and checked it againv- still over-filled - so i drained it and put back in about 4 1/4 qts after draining and re-installing the filter talso and it reads full now. 4 1/4 and its top dot on the stick, with 5 qts it was a goodf 1/2 inch over...cant explain it but def dont wanna drive over-filled...thoughts?
Offline
Sep 5, 2009, 08:03 PM
I'm guessing that even though you let it drain "bone dry" there was still a good amount of oil left, like in the lines to the turbo for example.
I just changed my oil for the first time with Mobil 1 and noticed the same thing...I drained everything and replaced the filter (which was slightly bigger than stock). The manual said it would take something like 5.4 quarts with a new filter, but I found that after 5 quarts it was a little over-filled too.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
Offline
Sep 7, 2009, 08:13 PM
That's weird??? I don't know what to say about it taking less than 5qts. I did mine for the first time about a month ago and after draining the oil and removing the filter 5qts was dead nuts on. Meaning it was filled up to the second dot but wasn't over. I did let mine drain for about a half hour as I enjoyed a few cold beers but didn't do anything special.
Offline
Tags
2009, change, changing, filter, g8, howto, impreza, lancer, location, oil, plug, pontiac, sport, subaru, super, xi  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
