Home Features Community Marketplace Registry Garage Store
Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Ralliart Engine/Turbo/Drivetrain
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Calendar Search Today's Posts Mark Forums Read Used CarsGarageVendor Directory
Search
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Thread Tools Search this Thread
Old May 9, 2011, 06:33 AM   #1
Personal Sales Rating: (0)
Garage is empty, add now
gloom's Avatar
Drives: A mountainbike, lol
ECU Logging/Display with Android Phone
I just want to suggest all of you (like me) that thinks evoscan is too much hassle and bulky to use, to check out the Torque app in android market.
I purchased the suggested obd2 bluetooth adapter from PLX and it worked out of the box.
You can output anything in either digital or analogue style gauges and put them however you might want, even on top of eachother.
Stuff it reads from my 2010 Ralliart:
SST Transmission Temperature(!!)
Engine Load
Engine RPM
Fuel Trim bank 1 sensor 1+2 (Long/Short Term)
GPS vs OBD Speed difference
Intake Manifold Pressure
MPG etc
Mass Air Flow Rate
O2 Volts Bank 1 Sensor 1+2
Throttle Position
Timing Advance
Trip Distance
Turbo Boost & Vacuum
Voltage
I am using the HDMI out on my phone to my car satnav for the picture and it's really a great and cheap alternative.
A question about accuracy.
The Trans temp varied between ~85 - ~95 when I checked it, does that sound accurate and what is the normal transmission working temperature?
Thanks,
T
__________________
SOLD -> _,-Amethyst Black 2010 Lancer Sportback Ralliart-._]
- 98 RON GST Basemap+Boost Pill Tune
- HKS High Performance Sports Filter
- INJEN Upper Intercooler Pipe Kit
- Swift Sport Springs
- Evolution X BOV
Daily Devil w/ ???whp
Offline
Old May 9, 2011, 06:52 AM   #2
Personal Sales Rating: (8)
Mad_SB's Avatar
Drives: 2013 Asphalt FR-S
Not bad, and usefull as a boost gauge and trans temp... thats about all though. Tactrix stand alone logger is a much better alternative for logging purposes and I have to imagine it would be cheaper to just buy a decent boost gauge.
Critical things you don't get:
- Load over 160 (160 was the old limit via obd)
- knock sum
__________________
SOLD: X-Swapped GG Ralliart SportBack Build Log
Old Whip: 93pump - 363 awhp @ Dyno Dynamics with 1.0 C.F. (448 hp shootout)
WW X GSR SSS | Blouch Dominator 1 | Cosworth MX1's | HKS EVC VI | Ultimate Racing 02 Back | RC 750cc | EcuTek Tune
Older Whip: 93pump 21psi - 340 awhp @ Dyno Dynamics with 1.0 C.F. (~392 dynojet)
LY VIII | AEM EMS | HKS 272's | FPGreen | Cusco Twin | Shep Stg2 TC | KW V3's | TE-37's
Offline
Old May 9, 2011, 07:17 AM   #3
gloom's Avatar
I already have a real boost gauge, but to me, it's mostly a visual element but it's more of a hobbyist tool then a professional tool, I agree, but I'm very much in the learning state and it's easy to use.
Besides, I really don't know how to log any of these values in EvoScan (For my 2010 AUS/EDM RA).
__________________
- Evolution X BOV
Offline
Old May 9, 2011, 08:03 AM   #4
Mad_SB's Avatar
If you already have a tactrix cable, check this thread out:
Logging with no Laptop - RA logcfg files here
Should have a ready to use config file for the stand alone logger as well as info on how to set it up.
__________________
Offline
Old May 9, 2011, 08:26 AM   #5
gloom's Avatar
I didn't find that thread before D: thanks.
I should be able to enter the "paramid"'s from the txt files into EvoScan to be able to log that value there aswell then?
__________________
- Evolution X BOV
Offline
Old May 9, 2011, 08:31 AM   #6
Mad_SB's Avatar
Exactly,
Though you may need to add back in 0x23 to the beginning of the paramid. I think i saw a thread with the xml for evoscan though...... I'll post it up if I can find it.
__________________
Offline
Old May 9, 2011, 05:04 PM   #7
Personal Sales Rating: (7)
razorlab's Avatar
Drives: a laptop connected to your ECU.
Thanks,
T
Log this in Evoscan and compare:
Code:
 <DataListItem DataLog="N" Color="" Display="SST Transmission Temp" LogReference="SST_TM_Temp" RequestID="CAN28-0" Eval="x-50" Unit="C" MetricEval="x-50" MetricUnit="Deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="1000" ChartMin="0" ChartMax="1000" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
__________________
Bryan
2005 5spd MR - E85 powered
2014 5spd Evo GSR - E85 powered
Offline
Old May 10, 2011, 12:41 AM   #8
gloom's Avatar
Thanks I will try all of this on ny free day off.
I still think torque looks alot better graphically so I will keep using it but check with evoscan from time to time if Im worried about knock.
__________________
- Evolution X BOV
Offline
Old Jul 26, 2011, 04:43 AM   #9
Core's Avatar
Drives: WRX STI MY04 ==> Ralliart X ==> EVO VIII
- knock sum
Is it impossible to tune Android Torque to show Knock Sum?
Offline
EvolutionM
Mitsubishi Lancer
Paid Advertisement
Tags
09, 20, android, app, bluetooth, dongle, ecu, evom, lancer, locator, logger, mobiucare, obdii, openport, phone, pro, ralliart, standalone, tactrix, unecu
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
All Passwords
