Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Ralliart Engine/Turbo/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 1, 2009, 07:06 PM   #1
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
New personal best 1/4 mile!
Took another trip up to US-41 dragway. I still am unable to log A/F ratio, so I haven't tweaked the A/F maps very much... just richened it up for high boost levels where the tune was a bit lean.
Track elevation 662 ft. Temperature 55 F. Vehicle weight with driver 3710.
My first run I F'ed up. Getting the data logger going I forgot to turn off ASC and forgot to switch the transmission into Sport mode. I ran a 13.399 @ 102.05
My second run was my new personal best... remembered to turn off ASC and switch to sport mode and pulled off a decent launch. I ran a 13.052 @ 103.70.
The car was feeling strong, and I think with one more run as temperatures cooled off a bit I would have gotten my 12 second run, but before my second run the left lane got messed up, and about 10 min before I would have made my 3rd run somebody oiled down the right lane
HP estimates based on track times are for fun, and comparison to other similarly derived estimates... that being said, my best run results in the following:
ET method 330 CRANK HP
Trap speed method 323 CRANK HP
It has been my contention in the past that the trap speed is more accurate, and I see no reason to change my tune when it is the lower of the two estimates of crank HP.
Theres always next weekend! If I have enough chances to run I may try holding 4th to the end... with my raised rev limits I can hit 107 mph at the top of 4th (7,500 RPM)... but boost drops off very fast after 6500 RPM so I don't know if the gearing advantage would be worth the boost drop... we may see next time I hit the track!
My only changes other than tweaking the tune just a bit was swapping out the test pipe for my high flow cat. My peak boost in 1st was 23.6 psi dropping to 15.6 at the shift, 2nd peaked at 22.7 dropping to 15.5 at the shift, 3rd peaked at 22.2 dropping to 16.7 at the shift, 4th peaked at 23.6 dropping to 16.5 at the shift, and finally 5th peaked at 24.8 and dropped to 22.6 at 5500 RPM where I let off due to passing the finish line. I only logged boost my first run to make sure it wasn't excessive, second run I tweaked my timing curve and logged knock sum.
Time slip will be posted in the drag race forum as soon as I get it scanned.
Later,
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Nov 2, 2009, 07:49 AM   #2
Personal Sales Rating: (4)
Drives: 09 RG Ralliart "Myra"
Send a message via AIM to IdriveRA
Good job, you def. picked a nice day to run it!
__________________
"Myra"
Tuned by AMS
13.5
Offline
Old Nov 2, 2009, 10:21 AM   #3
Personal Sales Rating: (2)
kaiten2's Avatar
Drives: 2009 RA
Congrats and good times. It would be awesome if you can break into the 12 sec mark good luck
__________________
No More 03 LY EVO K&N open filter cone intake, EVO IX BOV
09 Lancer RA some kinda blue lol
If NISMO stands for NISsan MOtorsports what would stand for HOnda MOtorsports?
Offline
Old Nov 2, 2009, 10:23 AM   #4
Personal Sales Rating: (0)
Drives: 09 Ralliart, Rotor Glow
How does turning off the ASC help? Does it help on the launch or just the entire drag run?
Offline
Old Nov 2, 2009, 10:58 AM   #5
Fourdoor's Avatar
Quote:
The track I run at actually has pretty good traction at the launch area, so it probably makes little to no difference. If the launch area is a bit slick it is a whole nother story!
The way our ASC works, is it cuts engine power for a second (not sure how long) if it detects wheel spin. On a drag strip run a little bit of wheel spin isn't good, but much better than having engine power cut off for a second or so... if that happens it is pretty much game over on a drag strip run, so you turn off the ASC.
Keith
__________________
Offline
Old Nov 2, 2009, 02:00 PM   #6
billyboy1's Avatar
Drives: Ralliart Lancer
that is good to know
nice run!
Online
Old Nov 2, 2009, 03:49 PM   #7
show time's Avatar
Drives: 2009 WW RA
Very nice indeed. If you weren't in the hatch you probably would have hit the 12 ish area. Nice sold run. Keep up the good work.
__________________
Injen UICP
Cosworth drop-in
Until Fed EX gets here with my damn orders.
Offline
Old Nov 2, 2009, 04:06 PM   #8
Fourdoor's Avatar
Quote:
Hell, if I had taken a dump before the run I probably would have gotten my 12!
I'm pissed at myself for not going earlier and getting more runs in, and for arriving with over 2/3 full tank of gas.
I just need to tweak my logger for the correct readout on A/F ratio, and I can get the A/F tune more accurate. Right now it swings between 11 and 12 at WOT high boost, I want to steady it down at a nice safe 11.5 to 1 and then start playing with the timing maps a bit now that I can log knock sum.
Keith
PS: After I get the 93 octane maps lined out I will start tuning on E-85 God I love that stuff!
__________________
Offline
Old Nov 2, 2009, 04:06 PM   #9
Drives: 09 ww ralliart
Nice run, now go get that 12 second pass
Offline
Tags
good, mile, quarter, run
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
