Oct 25, 2009, 01:37 AM
Personal Sales Rating: ( 0)
Drives: 09 ralliart
exhaust smells like oil
just put on test pipe two days ago cel is now on i am waiting for o2 spacer to come. but i did notice that my exhaust kinda smells like oil or maybe is it just running really rich? has any1 else that has installed a test pipe noticed this?
Offline
Oct 25, 2009, 06:46 AM
Drives: 2009 WW RA
Which test pipe and who made it? The smell could be burn off from your new pipe check to see if you are blowing out white smoke. Take your car out and run it around for a bit(not hard) to try and burn what is on the test pipe off. Then stop rev the car not real hard but give it some and watch the exhaust fumes and check for white smoke coming out. If it does for more then a day or so better get it checked out. Try this after you get your O2 CEL fixxed first.
__________________
Injen UICP
Cosworth drop-in
Until Fed EX gets here with my damn orders.
Offline
Oct 25, 2009, 06:50 AM
Drives: 09 ralliart
it is an ichiba test pipe. only problem is it so cold by me right now my exhaust is always smoking
Offline
Oct 25, 2009, 06:52 AM
Drives: 08 gts , 07 outlanderxls ,09 RA
pull the plugs and check them.
if you are burning oil...........you will know.
Offline
Oct 25, 2009, 06:58 AM
Drives: 09 ralliart
i know the car has always smelled really rich. but it kinda does smell like oil maybe its just from new pipe. but i have been driving it for three days now you would think that all the oil on the new pipe would have burned off by now
Offline
Oct 25, 2009, 07:07 AM
Drives: 2009 WW RA
Quote:
If you are burning oil...........you will know.
+1 ^
__________________
Injen UICP
Cosworth drop-in
Offline
Oct 25, 2009, 08:37 AM
Drives: 09 ralliart
i pulled the plugs and they look good. i guess it just must be the smell from how rich the car runs
Offline
Oct 25, 2009, 09:46 AM
Drives: Black 09 ralliart
I just installed a test pipe. It did change the smell of the exhaust. I have not noticed any smoking though. I would think that it is normal to smell different since it is missing the cat....Oh and I also have a cel. I plan to hook the output from my wide band to the factory sensor wire and see if this fixes it.
Offline
Oct 25, 2009, 05:19 PM
Drives: 2009 Mitsubishi Lancer Ralliart
I got a test pipe on mine and the exhaust fumes smell disgusting and even manage to get their way into the car when idling so i keep the vents in the closed position
Offline
Oct 26, 2009, 03:45 PM
Drives: 2009 WW RA
Sounds like you might have a leak. Or the wind was blowing from your rear blowing the fumes forward. Could be a leak tho. If so you deff want to get that fixed soon.
__________________
Injen UICP
Cosworth drop-in
Offline
Oct 26, 2009, 03:59 PM
How do you suggest I look for a leak?
Offline
Oct 26, 2009, 04:21 PM
Drives: 2009 WW RA
Take it out drive the hell out of it then put your hand on it and feel for leaks. LOL Just kidding. If its cold where u live it will be easy by visual inspection. Who put your pipe on?
__________________
Injen UICP
Cosworth drop-in
Offline
Oct 26, 2009, 07:12 PM
Uncle's shop, we plugged the exhaust tips and didnt really notice any leaks upon installation
Offline
Oct 27, 2009, 05:04 PM
Drives: 2009 WW RA
Well sound like your OK. Better safe then sorry but it seems a little odd.
__________________
Injen UICP
Cosworth drop-in
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
