Oct 24, 2009, 08:38 PM
Personal Sales Rating: ( 26)
Drives: 09 RalliArt; Lancer Evo IX MR; 1999 Honda Civic
Evo X IC and stock UICP coupler question!
All,
If I were to install the Evo X IC using the RA upper IC pipe, What will be the coupler size to get in order to fit the difference in height?
I have the Evo X LICP and will use it after the swap, but would like to use the stock upper pipe until I get an upgraded one.
__________________
Thanks!
-Joed
EVO MR 2006 - 403.08 WHP / 356.68 TQ - FPGreen // BR Stages 1, 2 & Race I/C // Nisei LICP // PTE 780CCs // Walbro 255 hp pump // Blitz iColor @ 25 PSI // LC-1 WB // GSC S2 // Defi BF w Gruppe-S Panel
Offline
Oct 24, 2009, 11:16 PM
Personal Sales Rating: ( 10)
Drives: 2010 Ralliart Sportback.
Quote:
Originally Posted by joedr
All,
I don't know if the EVO X IC inlet is the same size as the ralliart or not, I know that the Buschur Racing intercooler inlet is larger than the Ralliart, but I can't remember if it was the same as the EVO IC or larger. You will definitely have to cut the stock pipe since the EVO intercooler is taller.
If your new lower intercooler pipe includes the rubber section going from the aluminum pipe to the throttle body itself you can take the old rubber section from your stock lower IC pipe going to the throttle body and cut that to make a coupler. Since it is tappered you can get pretty much any diameter you need by cutting in the right spot
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Oct 25, 2009, 07:22 AM
Personal Sales Rating: ( 0)
Drives: 2009 WW RA
Also the X LICP outlet to your BOV is at a different angle. There is a wright up on this some where. Here check this out. http://streetimportonline.com/sio/mi...ed-engine.html
__________________
Injen UICP
Cosworth drop-in
Until Fed EX gets here with my damn orders.
Offline
Oct 25, 2009, 06:02 PM
I believe that the IC inlet on boths IC are the same size in diameter. Since the RA has a large (3-4 inches) coupler to get from the upper pipe to the IC inlet, I thought that cutting to size will be an option. But, decided to ask what length should I get the coupler to be able to accomodate the Evo IC without messing up the OEM parts.
Keith
Thanks for the heads up! Saw that link and I already planned for that minor difference there!
Quote:
Originally Posted by show time
__________________
Thanks!
-Joed
Offline
Oct 25, 2009, 08:19 PM
Personal Sales Rating: ( 2)
Drives: 2009 APEX Silver RALLIART
2.5 " coupler matches them up
__________________
[b][color="Silver"][X] 35% Window Tint
[X] Ralliart Sport Air Filter
[X] Evo X BPV
[X] Stage 1 ECU Flash
[X] GST Boost Pill
[X] Evo X FMIC
[X] UR UCIP
Waiting to Install:
[ ] Greddy Downpipe
Offline
Oct 25, 2009, 08:24 PM
Just to be clear.
2.5" in diameter * 2.5" in length coupler?
__________________
Thanks!
-Joed
Offline
Oct 26, 2009, 07:48 AM
Personal Sales Rating: ( 1)
Drives: 2008 TB Lancer ES-Sport & 2009 GG Lancer Ralliart
2.5" diameter; if you use the lower pipe coupler from an Evo X Front Mount it will mount on the Ralliart's lower pipe, they're the same diameter. The upper pipe is an issue so it would be best if you get a custom pipe, UR or AMS. They'll provide the coupler you can use or simply use the Evo X stock Upper Pipe and Coupler for that same pipe.
__________________
Current Mods:
Mucho cosas que warranty should be gone by now!
Offline
Oct 26, 2009, 08:14 AM
jazket,
So, you are saying that the inlet on the RA and Evo IC are not aligned on the horizontal axis? Are they off where no coupler will join them?
I am under the impression that the inlet of both ICs are on the position just different height.
Can you or anyone confirm this?
__________________
Thanks!
-Joed
Offline
Oct 26, 2009, 08:27 AM
lower pipe and front mount inlet are aligned on the horizontal axis the same way on both the Evo X and 09+ Ralliart. BUT, Ralliart FMIC lower inlet is smaller in diameter than Evo X FMIC inlet. There's a conversion on the Ralliart's Lower pipe and FMIC lower inlet. So use the Evo X FMIC lower inlet coupler, that will match the Ralliart Lower Intercooler Pipe with no trimming or cutting necessary.
If you plan on using the Stock Ralliart Upper Pipe you will need a conversion as well, from 2.5" (Evo X Front Mount Upper Inlet) to Ralliart Stock Pipe (about 2") and the length of the cloupler should be about 2 to 3 inches probably instead of the stock 6+ inches. In that case you should keep the stock Evo X Upper Pipe to Evo X FMIC upper inlet coupler, and use it on a custom upper pipe instead. Better airflow, metal instead of rubber, and better looking than stock.
__________________
Current Mods:
Offline
Oct 26, 2009, 11:19 AM
Silver Sponsor +1
Personal Sales Rating: ( 445)
Drives: 2008 Evolution GSR SSS, 2005 Evolution MR, 2003 Evo GSR, 1995 TsiAWD, 1995 GST, 1995 Tsi 2wd, 1991 GVR4 WW, 1991 GVR4 NBM, 1993 TsiAWD, 1991 Tsi, 1995 RS N20
We have all of these parts available from FMIC to Evo X turbo, manifold and O2 housing if any Ralliart owner is interested, PM us.
__________________
2005 Evolution VIII MR
763whp/595tq HTA86
10.19 & 143.3mph stock ECU
Factory ECU Expert
2008 Evolution X GSR
12.0@113mph Full Wt+
In House Mustang Dyno AWD-500!
www.ttp-engineering.com
(407) 475-0010
AIM=TTPEngineering
MODIFYING THE 4G63 SINCE 1995, YES 14 YEARS!
TUNING EVO V - EVO X & 2009 RALLIART!
TTP's Myspace page!
Offline
Oct 26, 2009, 12:15 PM
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Ralliart
Sorry I didn't get back to your PM earlier, joedr.
jazket is correct in that the inlet/outlet DIAMETERS are different between the RA and X intercoolers, with the X intercooler being 0.25" (I think?) larger.
I'm not sure what LENGTH of coupler you would need to connect the RA UICP to the X IC inlet. I can try to get some sort of idea for you later on tonight.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Oct 26, 2009, 01:01 PM
Quote:
Just calculate the height difference on the RA and X intercooler and cut that much from the stock RA upper pipe coupler
__________________
Current Mods:
Offline
Oct 26, 2009, 02:54 PM
True...just eyeballing it from my post (here: Stock intercooler core sizes) I'd say you'd need a coupler about 3" SHORTER than the stock RA coupler.
Quote:
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
Offline
Oct 26, 2009, 05:36 PM
Drives: 2009 WW RA
This would be great if you guys figured it all out for sure. EVO X FMIC is the mod I want to do the most.
__________________
Injen UICP
Cosworth drop-in
Offline
Oct 27, 2009, 08:57 AM
I thought that the diameter on the Evo X IC inlet and RA hot pipe was the same diameter. I will check the diameter on the RA hot pipe to see if there is a size difference between them.
BTW, I measured the Evo X LICP that connects to the IC and the groove Arrow 1 in pic below measures 2.5" and the area where the clamp goes (Arrow 2) measures 2.25". Not sure if that is the case on the RA hot pipe as well.
I will check on mine and report back.
__________________
Thanks!
-Joed
Offline
Tags
blitz, buschur, cat, couplers, cupler, evo, evolution, fmic, hks, install, intercooler, length, size, stock, turbo, uicp  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
