Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Ralliart Engine/Turbo/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 20, 2009, 07:58 AM   #1
EvoM Moderator
Personal Sales Rating: (26)
joedr's Avatar
Drives: 09 RalliArt; Lancer Evo IX MR; 1999 Honda Civic
Send a message via AIM to joedr Send a message via MSN to joedr
GST Base Map on 93 OCT and some tweaking!
All,
First of all... I would like to mention that I used the GST BoostPill Basemap (with the pill of course) and adjusted "Boost", Fuel and timing to match the 93 OCT. I could not log the AFR in Evoscan for cross reference but I was able to log it with the dyno WB attached to it. So, if needed please feel free to ask. Thanks to GST for the basemap!
Also, I am going back to finish the tune once I figure out the boost cut I was running into. More of this later!
The story... Yesterday I went to the dyno to test the performance of the RA on 93 OCT. Wow.... do they run rich as f%^k!
Here are the results:
I tried to increse the boost and me been noobie on the RA got the car to boost cut and limp mode. Yeap! I am a noobie on this new platform. Damn it!
Can anyone helped me on what tables need to be modified to achieve 23-24 PSI? As it seems that the 93 OCT was able to hold some good timing and was liking the increased of boost (22.7 max I was able to log just before the ECU going to idiot mode. I am confident that I could extract another 15 WHP and 10 lbs/ft with the increased boost easily.
Here are the tables used for the last pull. I would appreciate if anyone can point what was causing the car to boost cut and limp mode. I tried raising the Boost Limit Table with no success after 22.7 and could not figure out at almost midnight how to prevent that. Just need some clarification and will do the trial and error.
Thanks in advanced!
Offline
Old Oct 20, 2009, 12:11 PM   #2
Silver Sponsor
Personal Sales Rating: (4)
GST Motorsports's Avatar
Drives: EVO, STI
So the blue is stock and the red is with the basemap and pill or the red is basemap and pill and some of your own tweaking for 93?
I can send over a tweaked ROM for you to eliminate the limp mode.
I would like to see the logged AFR if you have it from the basemap.
- Bryan
__________________
GST Motorsports
2439 Industrial Pkwy. West Suite A
Hayward, CA 94545
510-264-9049
The original E85 Army
http://www.gstmotorsports.com
Offline
Old Oct 20, 2009, 01:11 PM   #3
EvoM Moderator
joedr's Avatar
Shoot me a PM with your email and will forward all the logs I have and the last rom used for the graph above. If you can forward the tweaked rom for eliminating the limp mode, please do so. I will pm you my email.
Also, I would prefer to have the boost cut and the OEM protection for overboost retained but adapted for the new boost level. I.E. Having the protection to be active if you get more than 25 PSI which should be the max I will try on the SST. With low 23 PSI target, the RA was hitting 258 TQ before it went to limp mode and boost forced to like 8 PSI. I was hoping to get a bit over 250 WHP with the extra boost.
Red graph is boost pill + some tweaking on 93 OCT. Blue bone stock rom with code23 enabled for logging.
This one is the stock rom versus your boostpill rom untouched. Good gains indeed!
Here is the close up of the AFRs - Stock and BoostPill.
__________________
Thanks!
-Joed
EVO MR 2006 - 403.08 WHP / 356.68 TQ - FPGreen // BR Stages 1, 2 & Race I/C // Nisei LICP // PTE 780CCs // Walbro 255 hp pump // Blitz iColor @ 25 PSI // LC-1 WB // GSC S2 // Defi BF w Gruppe-S Panel
Offline
Old Oct 20, 2009, 01:25 PM   #4
Personal Sales Rating: (0)
Drives: 2009 Lancer RA
Nice work, Joed! +40whp/+17wtq is awesome... and you think there might be more power!
Offline
Old Oct 20, 2009, 01:58 PM   #5
Silver Sponsor
Drives: EVO, STI
Thanks for the data, is this on a 100% stock RA?
This will help me develop the 93 oct base map.
Glad to see some 3rd party dyno testing too.
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Oct 20, 2009, 02:42 PM   #6
EvoM Moderator
joedr's Avatar
Not bad for just a flash ha! Should be going to the dyno as soon as I get the boost cut and limp mode issue sorted.
Yes! I think that the boost cut issue stole some of the dyno time and am confident that the car should hit 260 WHP at moderate boost levels.
Quote:
The only thing changed was the recirc valve which I swapped for a metal (Evo IX or Evo X one) one. If you want my logs, I can forward them to you. Also, I pm you my email if you have the rom that is limp mode free. I am pretty sure that a bit more boost will do wonders and should be able to extract some more hp/tq.
__________________
Thanks!
-Joed
Offline
Old Oct 22, 2009, 11:46 AM   #7
Silver Sponsor
Drives: EVO, STI
Nice work again, hopefully the beta 93 map shows some promise.
- Bryan
__________________
GST Motorsports
Hayward, CA 94545
510-264-9049
Offline
Old Oct 22, 2009, 12:49 PM   #8
EvoM Moderator
joedr's Avatar
Thanks! I will test it ASAP based on the dyno schedule.
I saw the changes on the BETA and they make sense. Will reply with the results.
Also, have you seen some timing pull at spool up. A third gear pull is showing 6 deg advanced at peak boost when the cell (Load vs RPM) is showing 10 deg and no knock whatsoever during the entire pull.
I even matched both timing tables to ensure will get that value but the ECU still skew it. Any idea what might be causing this?
__________________
Thanks!
-Joed
Offline
Tags
2006, 93, base, basemap, evo, forums, gst, joins, map, mr
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
