Oct 19, 2009, 09:36 PM
Personal Sales Rating: ( 0)
Drives: 2009 RA
AMS SRI installed
So I just finished installing my AMS intake. Started up the car everything seems fine no CELs so far. i'm gonna take it to my tuner and get a tune tommorrow at AM SHARP!!!!
One thing I noticed is that when I start the car it's idoling at around 1000 then it drops slightly and then it goes back up to 1000. I'm a bit nervous to even drive my car to the tuner. Can anyone suggest how I should drive it and on what gear????
__________________
AMS SR intake [X]AMS BOV Kit [X]
UR Turboback [X]
IVEY TUNED at 266whp/260wtq.
Offline
Oct 20, 2009, 08:35 AM
Personal Sales Rating: ( 1)
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Ralliart
If you are going to drive it to the tuner, keep the RPM's low and out of boost. Pretend like your elderly grandmother is in the passenger seat and she's trying not to spill her casserole all over your interior.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Oct 20, 2009, 08:58 AM
yeah what he said drive normal take it easy. or like one of the japan drift movies fill water all the way to the top of the cup put it in the cup holder and dont spill it lol
Offline
Oct 20, 2009, 10:10 AM
Drives: 09 Ralliart
^You are refering to Initial D. Anyways do what is suggested and keep it out of the boost range until you get to the tuner. Last thing you want is for you to break something on the way there.
__________________
Mitsubishi, Nissan, Mazda, Subaru
The Last of the Japanese performance brands forging ahead into the millenium.
Offline
Oct 20, 2009, 02:35 PM
Drives: 2008 TB Lancer ES-Sport & 2009 GG Lancer Ralliart
that is don't rev above 3k
you should've installed it at the tuner shop then drop it on the dyno and tell the dudes 2 get to work!
__________________
Current Mods:
Mucho cosas que warranty should be gone by now!
Offline
Oct 20, 2009, 03:01 PM
Drives: 09 Ralliart
thats what I'm doing, showing up to my tuning appointment early so i can install the intake in the parking lot lol
__________________
-BASE FLASH (NO BOOST PILL)
-ULTIMATE RACING FMIC
-ULTIMATE RACING CAT BACK EXHAUST
-AMS BOV UPGRADE
-ULTIMATE RACING SRI
<First 09 RA in 13's>
Offline
Oct 21, 2009, 07:35 AM
Drives: 2009 RA
driving 50 on a 65 is not fun trust me. Well everything is installed problem is my o2 sensor went bad so my tuner could not adjust the AFR correctly so I have to drive like this until I get an 02 sensor and take it back.
__________________
UR Turboback [X]
Offline
Oct 21, 2009, 03:50 PM
Drives: 2009 WW RA
 That sucks badly.
__________________
Injen UICP
Cosworth drop-in
Until Fed EX gets here with my damn orders.
Offline
Oct 21, 2009, 04:16 PM
Personal Sales Rating: ( 10)
Drives: 2010 Ralliart Sportback.
Ummmm, why did your O2 sensor go bad? You been running leaded race gas? if you have not been running leaded race gas keep in mind that a check engine light code for the rear O2 sensor also covers incorrect MAF readings... exactly what you would get from an upgraded intake. If your MAF readings are far enough out of whack it may even implicate the front O2 sensor... not sure on that one though.
If you are being tuned by a real tuner, they should have a wide band O2 sensor on their dyno, or if road tuning a portable wide band O2 sensor. What your stock O2 sensor is reading is irrelevant to tuning the ECU.
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Oct 21, 2009, 04:22 PM
Drives: 2009 RA
It's only the front that went bad.
__________________
UR Turboback [X]
Offline
Oct 21, 2009, 04:38 PM
Quote:
If you havn't been running leaded race fuel, there is no reason for it to have gone bad.... a whacked out MAF reading from driving the car un-tuned with an intake may have fouled the sensor at worst... take it out and clean it (don't ask me how... just don't use water  )
In reality I suspect that the whacked out MAF readings made the ECU think the O2 sensor is bad... not an actual problem with the O2 sensor. If the front O2 sensor shows you running very lean, and the ECU detects no problem with the MAF sensor itself, it will flag the front O2 sensor as being bad due to it reading lean. If you have a MAF problem causing you to run very rich it will flag the rear O2 sensor.
Keith
__________________
Offline
Oct 21, 2009, 09:42 PM
Drives: 2009 RA
Keith
This ain't the problem tho. I got the check engine light before I even put the intake on. It happened after I had my stock exhaust pulled out by my tuner then they had to put it back in because they sent me an EVO X catback parts which do not fit the RA. So basically it happened after the took the exhaust out and had to put it back in.
__________________
UR Turboback [X]
Offline
Oct 24, 2009, 07:26 AM
Drives: 2009 black ralliart, injen cold air, custom exhaust and valve cover paint.
that sucks, i hate that the evo X exhaust dosnt fit, for a while i couldnt find any parts for the RA.
Offline
Oct 24, 2009, 08:09 AM
Drives: 2009 RA
Ultimate Racing has the best customer service I told them that they sent me the wrong exhaust and they sent me the parts I needed the next day. Jerell is a good guy.
__________________
UR Turboback [X]
Offline
Oct 27, 2009, 04:28 PM
Drives: 09 WW RA , 98 Lifted F150
Quote:
That does suck, just imagine I thought the AEM CAi was the same for the RA, so i bought it and relocated my battery to the trunk to make it work. Only to findout it doesn't fit. For Sale! Evo X only........
__________________
http://www.youtube.com/watch?v=_QBrX2CoVsw
346 Hp 353 Tq
Evo X Turbo "ported" / Buschur Racing FMIC & IC piping / AGP Wastegate / Harman Motive Evo X Intake / Forge BOV / QTP electric cutout / HKS downpipe / Deatschwerks 800 cc injectors / Walboro 255 FP / Custom 3" test pipe / Catch can
TTP Tuned
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
