Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Ralliart Engine/Turbo/Drivetrain
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 11, 2009, 11:12 AM   #1
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
Forge WG actuator from EVO X confirmed!
Hey guys,
Just a heads up, the bolt pattern on the Ralliart turbo is the same as the EVO X turbo for connecting the WG actuator. The shaft is much shorter on the Ralliart stock WG actuator, but the Forge is adjustable, and at the limit of adjustment it is the same length as the Ralliart WG actuator!
Good news!
Keith
PS: my first mod is now on the car
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Oct 11, 2009, 11:25 AM   #2
silthos's Avatar
Drives: 03 lancer es turbo, 09 tarmac black ralliart
Send a message via AIM to silthos
Quote:
Originally Posted by Fourdoor View Post
Hey guys,
Good news!
Keith
Thanks for the info!!!
Offline
Old Oct 11, 2009, 05:26 PM   #3
Personal Sales Rating: (0)
What does it do?
Offline
Old Oct 11, 2009, 06:18 PM   #4
Fourdoor's Avatar
It increases boost pressure and keeps it from falling off as fast in the upper RPM's. After taking mine apart to re-orient the boost nipple, I think mine may be defective! So I gave the rod on the stock WG actuator a couple turns to increase the pre-load and left the Forge WG actuator off of the car. I am waiting for a response from Forge on the issue I discovered before I decide to use it.
Keith
__________________
Offline
Old Oct 13, 2009, 06:20 AM   #5
NASTYxNAT3's Avatar
Drives: 2009 GG Lancer Ralliart
Send a message via AIM to NASTYxNAT3
it also makes a really cool noise too. lol
how difficult is it to install Fourdoor?
Offline
Old Oct 13, 2009, 06:44 AM   #6
Fourdoor's Avatar
Ummm, it make no noise at all. This is not a BOV or bypass valve.... it is a wastegate actuator.
Keith
__________________
Offline
Old Oct 13, 2009, 07:06 AM   #7
NASTYxNAT3's Avatar
^opps my bad then.
Offline
Old Oct 13, 2009, 07:46 AM   #8
Drives: 08 gts , 07 outlanderxls ,09 RA
.......i "tightened" my stock waste-gate actuator 1 and 1/2 turns several months ago.
seems to be working well and with my minor amount of mods,
i do not think i will need an after-market actuator.
the forge is a nice part if someone wants it on their RA.
..........they have been working very well on the Xs' that have them.
Offline
Old Oct 13, 2009, 01:54 PM   #9
Personal Sales Rating: (1)
jazket's Avatar
Drives: 2008 TB Lancer ES-Sport & 2009 GG Lancer Ralliart
^ +1 I heard from a friend about turning the stock wga rod a couple times to allow for more boost pressure;
I really forgot about it, will try it out btw!
__________________
Current Mods:
Mucho cosas que warranty should be gone by now!
Offline
Old Oct 13, 2009, 05:35 PM   #10
Fourdoor's Avatar
Keith
I got a response from Forge today and re-checked what I thought was wrong with my WG actuator... turns out that I am retarded There was no problem with the unit and I will be putting it on the car in the morning.
Keith
PS: I would NOT recommend combining the forge WG actuator with a boost pill unless you are doing a custom tune on your ECU... an off the shelf boost pill tune is based on you having the stock WG actuator in place and would likely result in over-boosting!
__________________
Offline
Old Oct 13, 2009, 06:23 PM   #11
Drives: 09 Lancer Ralliart GG
give us the info... i have one laying around havent had time to drop it in
Offline
Old Oct 13, 2009, 06:35 PM   #12
Fourdoor's Avatar
Quote:
Ummmm, what info are you asking for?
Keith
__________________
Offline
Old Oct 14, 2009, 09:04 AM   #13
laflsyl10's Avatar
Drives: 2009 Ralliart
Can you please taka a picture where it is located and what we need to turn.
Offline
Old Oct 15, 2009, 04:59 PM   #14
Fourdoor's Avatar
Quote:
First remove the heat shield from the turbo.
__________________
Offline
Old Oct 15, 2009, 05:23 PM   #15
Fourdoor's Avatar
Then you will see the wastegate actuator attached to the firewall side of the turbo. It is held to the wastegate flapper on the passenger side with a cotter pin, and bolted the the compressor housing on the drivers side with two bolts (10 mm or 12 mm). It is easier to get too if you remove the upper IC pipe, and turbo inlet hose.
__________________
Offline
Tags
2010, actuator, bov, evo, firge, forge, intercooler, lancer, lower, pipe, putting, ralliart, tighten, wastegate, wg
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
