Oct 6, 2009, 07:41 PM
Personal Sales Rating: ( 10)
Drives: 2010 Ralliart Sportback.
gauges and gauge pods...
Well guys,
The best looking gauge pod I have seen so far is the triple pod from AMS. I need a boost gauge, wide band O2 sensor.... but what the hell do I put in the third position? I am most likely to leave it empty
Does anyone make a dual pod that looks as good as the triple from AMS?
Thanks,
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Oct 6, 2009, 07:48 PM
Personal Sales Rating: ( 1)
2009 Mitsubishi Lancer
Drives: 2009 Rally Red Ralliart
Transmission temp would be nice.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Oct 6, 2009, 07:53 PM
Personal Sales Rating: ( 0)
Drives: 09 ww ralliart
I concur
Offline
Oct 6, 2009, 08:19 PM
Gold Sponsor
Drives: 2009 Octane Blue Ralliart and AMS/NOS Energry Drink Drag Evo
Yes, we plan on doing Boost, UEGO, and trans temp! Good choices!
Offline
Oct 6, 2009, 08:50 PM
Quote:
I think I would lean more toward the Innovate Motor Sports lambda cable / O2 sensor system with the stand alone gauge.... http://www.innovatemotorsports.com/x...cat=262&page=1
It looks like the Tactrix setup is able to accept input from the Innovate system for logging purposes.
Now, if the AEM can also be interfaced with the tactrix system I would consider it since it is slightly less expensive.
I need to figure out how to tune this biach for myself... I had lots more fun with my 05 EVO and the AEM EMS than I did with a "set and forget" flash on my 08 MR.
Keith
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
