Sep 24, 2009, 08:53 AM
Personal Sales Rating: ( 0)
Drives: 2009 Mitsubishi Lancer RA
Check Engine Light
First off, I wanna start by saying HELLOoo!
This is my first post. I've been lurking around these forums for awhile now.. even before I got my Lancer. Lots of helpful stuff on here.
I own a 2009 Ralliart. Got it March '09.
In August the Check Engine Light turns on. The triangle with a big exclamation mark in the center. I checked the owner's manual and says that it may mean my timing chain is worn. I had 10,000km at the time......
It is now almost October
I brought my car in the the dealership several times
The last time replacing my timing chain and oil pump. On the work order it said something about something mis-aligned.
But guess what?? The light turned back on! This is now the 6th time it turned on for no reason. Any other owners having this problem?!?!?
FYI - my Ralliart is bone stock, only thing I did to it is window tint
The car drives great. Just this light keeps turning on for no reason.
Anyone have anything similar happen to them or know what I can do to fix this??
Thanks in advance
-Wes
Offline
Sep 24, 2009, 09:16 AM
Personal Sales Rating: ( 4)
Drives: 09 RG Ralliart "Myra"
hmm, no clue if you car is bonestock.
maybe the tint lol
__________________
"Myra"
Tuned by AMS
13.5
Offline
Sep 24, 2009, 10:21 AM
Drives: 09 rallifart
the easiest way to determine what it can be is actually get the error #.
Offline
Sep 24, 2009, 10:32 AM
Personal Sales Rating: ( 2)
Drives: 2009 RA
i always thought the triangle with the exclamation point was for the TPMS? everyother car ive seen thats what its for. But then again this is a mitsubishi so who knows lol
__________________
No More 03 LY EVO K&N open filter cone intake, EVO IX BOV
09 Lancer RA some kinda blue lol
If NISMO stands for NISsan MOtorsports what would stand for HOnda MOtorsports?
Offline
Sep 24, 2009, 12:11 PM
Personal Sales Rating: ( 1)
Drives: 2009 Lancer Ralliart, 1996 BMW M3
Well if it is the same thing sounds like you should get a new engine under warranty.
Offline
Sep 24, 2009, 10:53 PM
Drives: 09 Apex Silver Lancer Ralliart
^+1
maybe someone test drove the car before you bought it and just went crazy on it, no other explaination
Offline
Sep 25, 2009, 06:24 AM
Quote:
The triangle ! is a general warning light. It shows up any time there is something non-critical that requires the driver attention. Mine I've seen mine show up for TPMS and fuel, as well as the AWC computer going nute (note: turn OFF ASC if you are doing donuts...)
The check engine light is the universal "engine shape". You can only turn that off by clearing the DTC codes.
Offline
Sep 25, 2009, 10:30 AM
Drives: 2009 RA
thats what i thought. so then if he has the triangle with the ! then he should probably check the tire pressure
__________________
Offline
Sep 25, 2009, 11:32 AM
Drives: 2008 TB Lancer ES-Sport & 2009 GG Lancer Ralliart
Go to Autozone and have them read your code, come back and post it; we'll either know what it is or tell you 2 take it to the Dealer and have them read it and deal with the issue.
The triangle has nothing to do with the SES light like you say, the actual Service Engine Light is big and bright and just seeing it there gets anyone upset lol!
__________________
Current Mods:
Mucho cosas que warranty should be gone by now!
Offline
Sep 25, 2009, 02:09 PM
Sept.17
Cause: Scanned for codes DTC-P0012
Found Timing and Oil Pump not aligned
Correction: Replaced Timing Chain and Oil Pump Chain
Light turned back on Sept.23
This was code scanned by the tech at my dealership
I'm bringing it back Sept.28 so hopefully I'll get an answer
But yeah it's not TPMS light. It is big arse light in the middle of the display. I have to hold the info button to make it smaller and go to the top right of the screen. I have to do that every time I turn on my car... it doesn't even show the odometer until I do that. GAAAAH!
Well I'll update you guys once I get an answer back from
Offline
Sep 30, 2009, 06:12 PM
Drives: 09 Lancer Ralliart GG
keep us posted
Offline
Sep 30, 2009, 06:15 PM
Drives: 2009 Mitsubishi Lancer Ralliart
I hope all that was not paid for out of your pocket
Offline
Sep 30, 2009, 06:33 PM
2009 Mitsubishi Lancer My Garage
Drives: 2009 Ralliart/1992 Galant VR4/2007 Outlander XLS
If they don't get it fixed, file for Lemon law, make them replace the car with a new RA.
Get the local factory reps name and number and tell him/her your story. They will help.
Sounds like your dealership is as bad as mine.
Offline
Oct 1, 2009, 07:14 AM
Too bad there are no lemon laws in Canada. There is the Canadian Motor Vehicle Arbitration Plan, but I don't think it's as good as US lemon laws.
All the work done was covered under warranty. Except the last time they didn't give me a loaner car and I had to pay for a rental. Since my workplace is outside of their shuttle service. I spoke to the general manager so this time I got a rental free of charge.
I ended up going back to the dealership Sept.30 since it was a better time slot..
The mechanic had worked with Mitsubishi Techs to reprogram my car. They did a 150km road test to make sure light didn't come back on. He advised me that IF it comes back on I need to take down RPM, speed, time, temp., road conditions for him to diagnose.
I'm not really comfortable with the answer he had given me. It seems they still don't know what the problem is. I don't think they know what the real cause of the light going on and just reprogrammed it and hope it works. Maybe they solved the problem... if not, I'll end up writing in this thread again
-wes
Offline
Oct 1, 2009, 12:00 PM
Silver Sponsor
Drives: EVO, STI
P0012 is "Camshaft position- timing over-retarded"
We had this on a local Evo 10 and it ended up being a bad cam sensor. I swapped another cam sensor on and the CEL never came back so he ended up getting a new cam sensor from the dealer.
Offline
Tags
03, 2009, asc, check, engine, evolution, exclamation, honda, lancer, light, mark, mitsubishi, outlander, point, triangle, turn  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
