Sep 4, 2009, 09:59 PM
Personal Sales Rating: ( 0)
is LOWER INTERCOOLER PIPING really a necessary upgrade in our cars???
i just bought the ultimate racing upper intercooler pipe kit and was wondering how much of a difference the lower intercooler pipe kit would make. anyone have both upper and lower and notice a difference from the lower?
Offline
Sep 4, 2009, 10:06 PM
Personal Sales Rating: ( 10)
Drives: 03 lancer es turbo, 09 tarmac black ralliart
I have both. Dont think there's a difference but got it anyway.
Offline
Sep 4, 2009, 10:10 PM
thats what i was thinking. upper is obviously important cuz it improves airflow between the turbo and intercooler. but lower just going from intercooler to throttle body doesnt seem like it would be as necessary.
Offline
Sep 4, 2009, 10:19 PM
Drives: 2009 Lancer RA
If you are sticking with the stock I/C, it doesn't seem worth it to me to switch out the lower I/C piping. If you are upgrading the I/C, however, I would get a new lower pipe... just for fitment issues if nothing else.
Offline
Sep 5, 2009, 02:38 PM
Drives: 09 Ralliart
I was told the stock lower pipe has a bottle neck issue with it. I honestly haven't even looked at it myself on my car, but I have see a photo of one and there was a groove on it in the outside of the bend as it comes to the IC. Obviously that should affect airflow, replacing it would be worth while as long as it isn't expensive to do.
__________________
lilEvoX [x] Stock Evo X Turbo [x] Stock Evo X FMIC [ ] Stock Evo X BPV [x] T1R UICP [ ] CP-E exhaust
Offline
Sep 5, 2009, 03:23 PM
From what i've seen it looks pretty gnarly. Any smoothing or straightening of that pipng should increase spool. I'm installing an evo x intercooler and pipes when i get free time. I'll post pics for comparison.
Offline
Sep 5, 2009, 11:30 PM
Personal Sales Rating: ( 1)
2009 Mitsubishi Lancer
Drives: 2009 Lancer Ralliart Sportback
If the upper has a bottle neck and the lower doesnt, there will be negative effects.
If the lower has a bottle neck and the upper doesnt, there will be negative effects.
Its all part of the same system...
__________________
- Tuned by TTP Engineering
- CP-E QuickPower pipe
Offline
Sep 6, 2009, 11:07 PM
Personal Sales Rating: ( 5)
Drives: 09 Octane Blue Ralliart ...09 Lancer GTS(TOTALLED)
From seeing that the LICP has plastic and that it has a bottleneck, I'm gonna replace the LICP when I order my IC & piping.
Quote:
Originally Posted by dD Spikey
I'd recommend using the Evo X's LICP if you are going to upgrade the IC.
The Ralliart's LICP is plastic and is smaller than the Evo X's LICP. The Ralliart piece also has a bottleneck close to the IC.
There's one more issue though, The Ralliart's LICP touches the Evo X IC's outlet. The two ends push up against each other. It makes fitment a little bit difficult. You can see what I mean in this picture. Once you put on a coupler, it might be a bit harder. It can be done, and it will work, but you'll have to wiggle the fitment and probably push the LICP out a bit.
__________________
2009 Octane Pearl Blue Ralliart
2009 Octane Pearl Blue Lancer GTS CVT S&S (R.I.P. 7/8/09)
Offline
Sep 7, 2009, 02:36 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: EVO, STI
I find it funny that the Ralliart went to a composite IC to TB pipe, as the Evo 6 had this as well..
Offline
Tags
2009, effect, fitment, gts, intercooler, issues, lancer, lower, pipe, piping, racing, spool, time, ultimate, upgrade, upgraded  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
