Since I have had such a great 2009 year so far, and to give a bit back to the community I have been a part of for years, and just for the general "what the hell" of it....
UPDATE: 2009-2010 USDM/CADM and AUS 91 oct basemaps, 2009 USDM/CADM 93 oct basemaps!
2009 Mitsubishi Lancer Ralliart GST Motorsports Base Map Roms:
These are for a 100% Stock 2009 Lancer Ralliart!
2009 USDM/CADM - 91 oct - StockPill
2009 USDM/CADM - 91 oct - GST Boost Pill Upgrade
2009 USDM/CADM - 93 oct - StockPill
2009 USDM/CADM - 93 oct - GST Boost Pill Upgrade
2009 AUS - 91 oct - StockPill
2009 AUS - 91 oct - GST Boost Pill Upgrade
2010 Mitsubishi Lancer Ralliart GST Motorsports Base Map Roms:
These are for a 100% Stock 2010 Lancer Ralliart!
2010 USDM/CADM - 91 oct - StockPill
2010 USDM/CADM - 91 oct - GST Boost Pill Upgrade
ALWAYS SAVE A COPY OF YOUR STOCK ROM BEFORE FLASHING!!!!
Here is a dynochart showing the typical gains the 91 oct 2009 BaseMap with stockPill makes over stock: (This test performed Sept 5th)
Here is a dynochart showing the typical gains the 91 oct 2009 BaseMap with Upgraded Pill makes over stock: (This test performed Sept 5th)
As you can see the addition of the upgrade boost pill and BaseMap (for upgraded pill) gains much more throughout the meat of the powerband than with just the BaseMap and stock boost pill.
Here is a overlay of the differences between the boost pill upgrade BaseMap and the stock pill Basemap:
What this is:
1. This is for a 100% stock 2009-2010 Lancer Ralliart, stock meaning stock pill, stock intake, stock exhaust, stock everything.
(or a stock car with a GST upgraded boost pill and our BaseMap for it)
2. A base map for you to run for a bit more kick than factory
3. A base map to build your own custom tune on if you have aftermarket parts
4. These base maps are based off data that we have collected from custom tuning the 4B11 motor in multiple Ralliarts and Evo 10's. You can see some examples of our tuning on Ralliarts here:
Ralliart + EcuFlash =
Ralliart + BaseFlash + Boost Pill Upgrade = Tons o' data
What this is NOT:
1. Do not use for profit. This is me giving back to the community, use it for good, not evil.
2. Do not use on a RA with a aftermarket intake! Intakes need to be custom tuned with a wideband!
3. Do not use the non-pill BaseMap with a upgraded boost pill!
4. No moaning or requests for changes. It's
free.
Some more in depth information about this rom:
1. This was created from multiple 2009-2010 Lancer Ralliarts
2. Boost target is approx 18-19 psi peak (from approx 18 stock), tapering down to 13psi at 7k (from approx 9-10psi stock).
For our upgraded boost pill, the boost targets are 20-21psi peak, tapering down to 15psi.
3. Mode23 logging is turned on for your logging pleasure
4. This Rom is provided AS IS with no guarantees or warranties. USE AT YOUR OWN RISK, GST Motorsports is not responsible for any motor damage derived from the use of this rom or variants of.
What you need to flash this to your Ralliart:
1. A laptop. You can find netbooks for $300 and under nowadays, just make sure they are not linux.
2.
A Tactrix 2.0 OpenPort reflash cable
3.
OpenEcu EcuFlash software
You probably also want to log the car and do any adjustments from there.
Evoscan v2.6 works with the Mode23 logging already setup in the rom. This can log ignition timing, knock, boost, etc
UPDATE: Tested another 09 Ralliart, Sept 12th, 2009:
The log of the pull above:
If you would like to log:
Use EvoScan v2.6 Full :
http://www.limitless.co.nz/
Download, install
Once in EvoScan:
1. Select "OpenPort 2.0 (J2534/CAN/EvoX)" radio button
2. Select "CAN 2006+/EvoX" check box
3. Under the "Select ECU" Drop-down, select "mode23 USA RA EVOX"
Check off only these parameters to log:
Throttle Posn
2-Byte RPM
Load (Fuel)
TimingAdv
Knock Sum
PSIG
ActiveWGDC
ActiveWGDCC (Wastegate Duty Cycle correction)
Intake Air Temp
Manifold Air Temp
Coolant Temp
And if you have a wideband, connect it to your laptop and check off the wideband logging in EvoScan.
The best logs would be a full RPM sweep of 3rd and/or 4th gear on a level road. Log the car in Sport Mode so it won't shift on you.
Boost pill location:
Have fun!
- Bryan @ GST
