Official Wheels/Tires/Stance PHOTO and Spec Thread
Ok, so here's my vision: A place where everyone can come to look at PICTURES of everyone's setup as far as wheel/tire fitment and vehicle lowering is concerned.
This thread will be for PHOTOS AND SPECS ONLY. Please give as much information and detail as you can, including:
- car model, year
- wheel brand, diameter, width, offset
- tire width, sidewall height
- suspension modifications (related to stance or fitment, ie. springs/coilovers, camber kit, you get the point), also include alignment specs if you can
- whether or not you had to do any body modifications (like fender rolling, etc.)
Again, I would like to keep this a picture ONLY thread as much as possible. If you have a question regarding specifics and clarification on someone's setup, that's fine, but if anyone says "sick car man, that looks hot" - it's getting deleted, if anyone says "damn, those tires stick out like a dog's *****" - it's getting deleted, I think you know what I'm getting at.
I hope that many of you will contribute your photos and specs because there is a good amount of diversity among our group and it accommodates many different tastes and styles. If, however, you are running stock wheels/tires, I would ask that you not post here unless you have some modification (other than a basic drop on springs or something) that you feel stands out and would help give others an idea or advice to progress their own builds like spacers and wide tires and lowered and what have you *coughryangatescough*
I'd like to keep this as organized and relevant as possible for quick reference for anyone looking for ideas or direction with their setup. Most people have their own build threads, or contribute to the color-coordinated photo threads as well, so send the high-fives and props that way, or even better, through pm.
- car model, year
Allow me to give an example:
-2009 Ralliart Sedan
-R1 Racing "Hype" 18x8 +40
-Stock Yokohama 215/45
-Lowered on RRM springs, Ingalls front camber kit, Toe completely Zeroed, -2.0* camber front, -1.6* camber rear
-No rolling or body-modification required
And another:
-Enkei RPF1 17x8.5 +30
-Hankook Ventus V12 Evo K110 245/45
-Fender roll required in Rear Only
- Apex Silver Ralliart, 2009
- XXR 518, 18x8.5 +48
- Continental DWS 235 35
- RRM Grip Springs with 5mm Ichiban hub centric wheel spacer (spacer for rear wheels only)
- No fender rolling
- No fender rolling
GREAT IDEA!!!
-2011 Ralliart Sedan
-Evo VIII Enkei's 17x8 +38
-Falen Azenis RT-615 255/40/17
-Megan Street Coilovers. Front camber -2.7, Rear Camber -1.6
-Rears are rolled
Same setup as above but with Nitto Nt-01 245/45/17
-Rears are rolled
2011 Ralliart
Stock (stretched) 215/45/18 Advans
Stock 18x8.5 +38 GSR wheels
Eibach Pro-Kit 1.2" drop front/back
No fender rolling necessary
Plans are to eventually replace stock tires with 235s once I'm done tearing these up.
2011 Octane Blue Ralliart
Work Emotion XD9 18x9 +30
Nexen 5000 245/40/18 (Whack Tires) Soon to be on 235/40/18 NT05
RRM Springs w/ No Alignment after the Springs were installed.
**Fronts Clear with 100% No Issue, Rears PITA Roll the Rears ALL THE WAY and Maybe a Slight pull will help clear the 245's on stock shocks of course A Simple roll will help a smaller tire**
245/45/17 on +35 17x8 TSW Nurburgring
Powder coated locally
OEM Suspension *Full roll, no pull in rear only
Cosworth Drop in
RRE ABE
SCCA D-Stock Stickers
Cosworth Drop in
RRE ABE
