Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Ralliart Brakes/Wheels/Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 17, 2009, 12:28 PM   #1
Personal Sales Rating: (0)
fender roll...
Anyone know where would be a good place to get a proper fender roll done at? And an estimate on how much? It just makes the fenders wider right?
Offline
Old Oct 17, 2009, 01:02 PM   #2
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
Quote:
It crushes down that inner lip of the fender that projects inward towards the tire. If you roll the fender enough to actually change the shape as viewed from the outside you will need paint work because the paint will not stretch like the metal will.
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Oct 17, 2009, 04:07 PM   #3
billyboy1's Avatar
Drives: Ralliart Lancer
spot on - you will need touch up paint / take your car to a bodyshop if you flare your guards
Offline
Old Oct 30, 2009, 08:03 AM   #4
SlowG07's Avatar
Drives: 2009 TB Ralliart
If you was in Florida I would do it for you. I did mine already with no problems at all. I rolled them flat, all you need to do is get a heat gun and he the metal up really good before you start rolling it and take your time with it that way the paint doesn't chip off. As long as you keep the metal that you are rolling hot to the touch you shouldn't have a problem. Just don't let just anyone touch your car because they can mess up your paint.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
