Sep 16, 2009, 09:03 PM
Personal Sales Rating: ( 1)
Drives: Ralliart
Corner Weights - Suspension setup
After installing the BC coilovers I have setup the suspension to the following:
Front Caber -2.2 degrees
Rear Camber -1.2 degrees
Rear to front rake -3/8”
Corner weights to 50% with a total car weight of 3377lbs (Drives weight not included but was added for corner weight measurements)
The BC coilovers allowed me to set the ride height at the desired camber. I then scaled the car and made small ride height adjustments until the car was within 1% cross weight. I then adjusted the spring tension to get to exactly 50% cross weight. Total time was less than 2 hours.
The car has significantly more front end grip. Is compliant and behaves much better under braking.
I still have the ability to dial in more camber and or rake if needed.
Offline
Sep 17, 2009, 01:28 PM
Personal Sales Rating: ( 0)
Drives: 09 Lancer Ralliart
Pics.. Pics.. Pics
Offline
Sep 17, 2009, 01:40 PM
Personal Sales Rating: ( 2)
Drives: 2009 Lancer GTS BLK/BLK , 2008 Mitsubishi Lancer Es
dude i want to check out your RA
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
Offline
Sep 17, 2009, 02:06 PM
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
What about castor?
Offline
Sep 18, 2009, 05:55 PM
Drives: Ralliart
The caster numbers are not finalized yet. Long story short I have ordered a better rim clamp for my caster camber guage (also called dunlop clamp) I can not get an acurate reading at this time. More to come on this one. When I did the initial alignment (on a pro rack) I was showing in the 2.2 range but again is not the final setting.
Mark
Offline
Sep 18, 2009, 06:20 PM
2007 Subaru Impreza
Only 2.2, that's really low castor.
Offline
Sep 19, 2009, 09:26 AM
Drives: 08 gts , 07 outlanderxls ,09 RA
Quote:
.......stock castEr is 2.2 - 2.4..................
so what is "really low" about 2.2 that he has ? ?
Offline
Sep 19, 2009, 09:37 AM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
What about castor?
Caster.
Offline
Sep 19, 2009, 12:04 PM
2007 Subaru Impreza
2 degrees of caster sounds really low to me, which can hurt handling.
Offline
Sep 19, 2009, 12:05 PM
2007 Subaru Impreza
Quote:
Originally Posted by otter
Caster.
Damn you spelling weasel  .
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
