Aug 30, 2009, 02:08 PM
Personal Sales Rating: ( 0)
Drives: 2009 Lancer Ralliart
Black Dust from the brakes
Hi,
I just need some info about other 2009 Lancer Ralliart owners here. Does your Ralliart also produced insane amount of black dust, my rims are always dirty due to this, and not only that but also my lower portion of the front and rear doors has plenty of black spots that can be seen when you look close to it.
Any info will be greatly appreciated
Offline
Aug 30, 2009, 02:48 PM
Drives: 2009 Lancer RA
Yes, the brakes do produce an excessive amount of dust.
Offline
Aug 30, 2009, 07:37 PM
2009 Mitsubishi Lancer
Drives: 09 Ralliart
I don't have that problem, hardly any at all. what's ur driving style? or have you messed with the brake system?
__________________
[X] AMS stage 2 Flash
[X] AMS Compact Batt Kit
[X] AMS Polished SRI
[X] AMS Cat Back Exhaust
[ ] AMS Front Mount Inter Cooler
[ ] AMS Upper IC pipes
[ ] AMS Evo VIII BOV
[ ] AMS Trans Cooler
Offline
Aug 30, 2009, 07:45 PM
Just normal driving, I have no mods and I don't race the car too. Now my lower portion of the front doors and portion of the bumper behind the rear wheels has those black spots that will be a pain to remove. it could not have been normal bec its too excessive.
Offline
Aug 30, 2009, 08:10 PM
Personal Sales Rating: ( 1)
Drives: WW 09 Lancer Ralliart
i have white wheels so i notice a bit of build up in the grooves but takes nothing to clean. but i wash my car 2-3 times a weeks so nothing really stays long.
__________________
(x) Change in the ashtray
(x) a pack of gum in the cup holder
(x) performance wiper fluid
(x) oil change
(x) another pointless list nobody cares about
Offline
Aug 30, 2009, 09:51 PM
Drives: 09' Ralliart
Try putting some wax on your rims too. Helps the dust wash off.
If you have a heavy foot and stop and go a lot, there'll be more brake dust than just highway cruising.
Online
Aug 30, 2009, 10:39 PM
Thanks for the replies, any other suggestion? will putting of mud guards help to at least protect the body of the car from getting it?
Offline
Aug 30, 2009, 11:08 PM
Quote:
2-3times a week? wow lol
Offline
Aug 30, 2009, 11:39 PM
mostly 2 times. we have alot of road construction going on here so its pretty hard to keep clean right now..
__________________
(x) oil change
Offline
Aug 31, 2009, 10:16 AM
Drives: 09 Ralliart
Get wheel cleaner, Meguiars or Eagle One and then buy Eagle One Rim Dust Protectant Spray. That is what I use and it stays clean for about 2 weeks depending on how and where I drive. Shouldnt cost more than 11 bucks to get it.
__________________
Mitsubishi, Nissan, Mazda, Subaru
The Last of the Japanese performance brands forging ahead into the millenium.
Offline
Sep 1, 2009, 07:55 AM
Thanks for the advice, any suggestions on how to prevent or minimize it going to the actual body of the car, specifically just around the fenders?
Also how do I remove the black dots on the body, because scraping manually might damage the paint.
Quote:
Offline
Sep 1, 2009, 08:46 AM
Drives: 2009 Rally Red Ralliart
This would help to a certain degree...
Not sure what "black dots" you have, but some gentle rubbing with some Bug/Tar remover might be what you need.
__________________
[x] EvoX FMIC
[x] T1R IC Pipes
[x] HKS Drop-in Filter
[x] Rally Armor UR Flaps
[x] Blacked-out Trim
Offline
Sep 1, 2009, 10:42 AM
Drives: 09 Ralliart
Well as far as I know any kind of stuff that gets on paint that is road grime typically can come off with a clay bar and cleaner wax from Meguiars. Be sure to Wash the car first and then Clay bar and after Wax it with a good hand style applicated wax. I Typically wax the car once a month to keep the water at bay. In any case though if you put on tire shine after a good wash you will see black spots along the lower side of the car and also on the sideskirts after driving because you may have to much shine on the tires.
As far as the black spots on the rims near the inside of the spoke area i would say use your nails or a green scouring pad like the ones used on kitchen pots and pans.
Hope this helps
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
