Jul 16, 2009, 12:28 PM
Personal Sales Rating: ( 0)
Drives: 2009 MITSU RALLIART, 1969 Ford Mustang 302
Negative Camber?
so my RA has about 21,100 miles on it now thanks to a trip to florida and i noticed that my front tires had been getting really worn but when i checked him today the inside of the driverside tire feels like its showing belt and the passenger side is fine.
This sound like a camber problem?
__________________
(X) Ultimate Racing Exhaust
(X) Ultimate Racing IC Piping
(X) Ultimate Racing Downpipe
(X) Ultimate Racing Testpipe
(X) Forge Diverter Valve
(X) Glowshift Boost Gauge
Offline
Jul 16, 2009, 01:58 PM
Drives: 09 Ralliart
I noticed that my tires are eating tread like crazy on the inside on the front two.
__________________
Mitsubishi, Nissan, Mazda, Subaru
The Last of the Japanese performance brands forging ahead into the millenium.
Offline
Jul 16, 2009, 02:02 PM
Drives: 03 evo 8/ 06 R6
a couple of things. Evos and RA's run more camber than what would be in lets say a honda civic, or a escort, part of the many factors that help them corner so well. another note is you guys did not follow the factory tire rotation specs..something almost everyone (including me) fail to do.
__________________
The measure of a good car is how well it reacts in all road situations, NOT just how fast it goes straight.
Offline
Jul 16, 2009, 02:20 PM
Drives: 2009 Lancer RA
Quote:
+1
I try to rotate my tires every 5,000 miles or so, and when I forget, I pay the piper.  There are some tire rotation guides available on the Internet. I am too lazy to look them up right now, but you should find one that directly pertains to AWD vehicles.
What I like to do is move the fronts to the opposite-side rear and the rears forward on same side. Repeat the process each rotation.
Offline
Jul 16, 2009, 02:37 PM
Personal Sales Rating: ( 1)
Drives: 09 Lancer Ralliart GG
^+2
Offline
Jul 16, 2009, 02:51 PM
Personal Sales Rating: ( 5)
Drives: Blue 2004 Evo, 1969 Datsun 2000 roadster.
Camber aint the issue, Toes is your problem...get it checked. Camber effects toe which wears out tires on the inside /outside. Set toe to 0 and your probs will be solved regardless of camber.
Offline
Jul 17, 2009, 03:32 AM
Personal Sales Rating: ( 3)
2002 Ford Focus
Drives: 2002 SVTF, 2006 Honda Aero, 2008 Lancer GTS, 2006 Galant GTS
Quote:
This is the correct answer.
Offline
Jul 17, 2009, 07:05 AM
The only way to adjust it is through a shop correct?
__________________
Offline
Jul 17, 2009, 08:37 AM
Drives: 08 gts , 07 outlanderxls ,09 RA
go to a good alignment shop. ( ask some "hot rod" guys in your area. )
get toe as close to zero as possible.
get camber set to NEGATIVE .5 to 1.0 degree.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
