Aug 24, 2009, 03:20 PM
#46
Personal Sales Rating: ( 0)
Drives: as fast as humanly possible.
Quote:
Originally Posted by secondchace
ive decided im gonna go with 17x 8.5 wheels.
Allows for more tire which is what i want
They usually say that u shouldnt go below oem. Are you gonna run 50 profile instead of 45? I mean either way the back of the wheel may still rub if u lower it.
Online
Aug 24, 2009, 03:43 PM
#47
Drives: 09 rallifart
i will run 50 series, but i will gauge the sire wall size.. running a 245 instead of the 255 will drop the overall height of the tire.
Offline
Aug 24, 2009, 04:00 PM
#48
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
I would suggest running a thinner wheel if you're attempting that tire width. There's no need to jump down to a 17" wheel to run a 245, plus it doesn't make much sense to increase the sidewall size (and thus increase flex) in order to run a wider tire, you're basically offsetting any gains that would be observed from the larger contact patch. On an 8.5" rim, I suspect you'll need to roll the fenders. I'm on a 17 x 8 wheel right now and I rub slightly in the rear when there's weight in the back. I have 245/40 tires. If I was going to do it again, I'd run the same wheel size but get a 235/40 tire.
Online
Aug 24, 2009, 04:32 PM
#49
the reason for the 17's is to reduce the overall weight + i like the look.
I would probably go with the 235 45 17 to avoid rubbing and get a slightly tugged look on the tires themselves.
17x8.5 may require minimal rolling, but i have the tool and am fine with using it.
Offline
Aug 25, 2009, 11:35 PM
#50
Silver Vendor 2004 EvoM Shootout Champion
Personal Sales Rating: ( 23)
Drives: evo8
Robispec prepped the sportback in the OP #1 picture...
a few misleading posts in this thread...the ralliarts have ZERO camber adjustability...front or rear
the rear gains camber more than the front as you drop the car.....
the stock "understeer/PUSH" gets worse because of this...
We used aftermarket camber bolts in the front to get the correct camber and the wheels fit within the fenders ZERO mods...
We had to ROLL THE HECK out of the rears...but it came out well.
LAST THIS CAR IS TOO LOW! We did thai at Mitsu's request to provide an aggerssige stance and test some prototype springs...the testing is done. the car will be 1" HIGHER front and rear.
Group buy for the first run of springs is going on NOW!
__________________
ROBISPEC///
EvolutionM Tuner Champion 2004 ///EvolutionM Nitto Tire Champion 2006 ///1st Open Touring Challenge T-3 /// 2nd Limited AWD SS time attack /// 1st SCCUSCC Roadrace /// 1st & 2nd NASA TT Unlimited Class 2005 ///2nd TTR NASA Nationals 2006
"BEST turning AWD EVO, I've driven!" - Best Motoring's Keiichi Tsuchiya
Partners:
Buschur Racing /// Mike W /// KW /// Whiteline /// ENKEI /// Nitto Tires ///STASIS ALCONS /// APR
robispec.com
"...live a little!"
Offline
Aug 26, 2009, 03:30 AM
#51
How much?
Online
Aug 26, 2009, 03:43 AM
#52
Drives: evo8
__________________
ROBISPEC///
Partners:
robispec.com
"...live a little!"
Offline
Aug 26, 2009, 03:46 AM
#53
sit 1" higher from the OP's pic? will sit too high..not low enough
Offline
Aug 26, 2009, 03:56 AM
#54
Drives: evo8
Sorry when you go too low the car looks great but you make the handling worse..something robispec isn't known for.....
__________________
ROBISPEC///
Partners:
robispec.com
"...live a little!"
Offline
Aug 26, 2009, 08:30 AM
#55
Drives: 08 gts , 07 outlanderxls ,09 RA
robi.......thanks for clearing up the "camber debate" when lowering the R.A.
i took apart one side of my front suspension in anticipation of eventually lowering
my RA when i found a spring set i liked. i could not find a way to adjust anything
alignment wise ( except for toe ) as the car was assembled from the factory.
robi.... can we use any 14mm camber bolts that are the right length on the RA ?
......or....... is there a specific brand and size tht works best.
Online
Aug 26, 2009, 11:29 AM
#56
Drives: evo8
I use the whiteline parts but get them in "bulk" lol
__________________
ROBISPEC///
Partners:
robispec.com
"...live a little!"
Offline
Aug 26, 2009, 01:12 PM
#57
i went to the "robi" web site , but found nothing about 09 RA parts.
so how much is the drop for the new springs.
i am hopeing for............. 1" front , 1" rear........and STIFFER than stock.
Online
Aug 26, 2009, 01:29 PM
#58
Personal Sales Rating: ( 1)
Drives: 2008 TB Lancer ES-Sport & 2009 GG Lancer Ralliart
This post of yours made me happy! Sign me in!
__________________
Current Mods:
Mucho cosas que warranty should be gone by now!
Offline
Aug 26, 2009, 03:20 PM
#59
Drives: evo8
Quote:
thanks go and sign-up pay the deposit....the FIRST TEN WIN! lol
Ralliart lowering springs group buy sept delivery
__________________
ROBISPEC///
Partners:
robispec.com
"...live a little!"
Offline
Oct 30, 2009, 08:52 PM
#60
Drives: 2009 black ralliart, injen cold air, custom exhaust and valve cover paint.
those wheels look good
Online
Tags
09, 2009, bbs, evo, fenders, fit, forum, lancer, mr, ralliart, rolling, stock, weight, wheel, wheels  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
