Aug 20, 2009, 09:18 PM
#31
Personal Sales Rating: ( 0)
Drives: 09 WW Lancer Ralliart
Can you provide us with the specs for the stock evo grs wheels  thanx
Offline
Aug 20, 2009, 09:21 PM
#32
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
It's not just the series but the actual physical size of the tire. If I recall, the Ralliart has a 215/45/18 tire while the Evo is a 245/40/18. Based on this the Ralliart has a sidewall height of 96.75 mm while the Evo has a height of 98 mm. You would be amazed at how much a tire/wheel moves as you drive. I rub with a heavy load in the back and I'm on the stock suspension (which, as you can see in my profile, is SUV tall). Something that hasn't been mentioned is potentially running stiffer springs to stop rubbing. It's not the most elegant solution but it works.
Online
Aug 20, 2009, 09:53 PM
#33
Gold Sponsor
Drives: 2009 Octane Blue Ralliart and AMS/NOS Energry Drink Drag Evo
The Ralliart tire is actually a tad taller than the Evolution tire.
If you put people in the car and drive down the interstate the rears will rub BADLY. It started tearing our tires up so badly, we had to stop and buy a wooden bat at K-Mart and do some emergency fender rolling or we wouldn't have made it another 50 miles before getting a blowout. It was shaving huge pieces of rubber off and they were flinging around getting rubber all over the paint.
Offline
Aug 20, 2009, 10:05 PM
#34
2007 Subaru Impreza
Really? Do the narrower wheels make the tires taller or something?
Online
Aug 20, 2009, 11:10 PM
#35
Drives: 09 rallifart
they sure do.
http://www.miata.net/garage/tirecalc.html if your looking for a good guide.
Offline
Aug 21, 2009, 03:34 AM
#36
Drives: 2009 Lancer Ralliart
Does anyone know the best place to buy a set of the MR, GSR wheels?? Would ebay be the best place?
Offline
Aug 21, 2009, 08:23 AM
#37
Drives: 08 gts , 07 outlanderxls ,09 RA
in simple terms.................
the evo-x wheel i 8.5 inches and has +35 offset. RA is 7 inches with +45 offset.
if you put the evo-x wheel on the RA , they will "stick out" of the fender wells.
yes , they will rub even at stock height , so you could not lower your RA....
.......and you will still have the huge retarded gap above the front tires.
if you like the look of exo-x wheels.....
get some that look the same , that have the proper fitament for the RA.
Offline
Aug 21, 2009, 10:18 AM
#38
you can make the evo x rims fit without rubbing.. run thinner tyres maybe 225's, when lowering maybe opt for stiffer springs and run some neg camber.. also rolling guards..
someone here is running 18x9 +36 or so i think it was on 235/40.. and is lowered on RRM springs and all he had to do is roll his guards and the rubbing issues were fixed..
Also someone fitted the evo x rims on their ralliart on another forum and said theres no rubbing at all on stock height..
Offline
Aug 21, 2009, 11:08 AM
#39
Personal Sales Rating: ( 11)
Drives: 2009 WW Ralliart, 2003 WW EVO 8
Any weight in the rears will make it rub. You need to have +40 offsets...
I believe exo x wheels are +38 offset.
Even hard cornering will make the rears rub. Just the rears...
__________________
Bom
Offline
Aug 21, 2009, 01:30 PM
#40
Drives: '09RA and '88 Silvia
It looks like it you lowered it and camber the tires, roll the fenders. It looks like it would work. 1.5-2* of camber might do it. Looks possible.
Offline
Aug 21, 2009, 03:37 PM
#41
yes..........you can do alot of work and "make" the evo-x wheels and tires fit an RA.
but what would be the point. just buy wheels that fit......
..... so you can lower it , run a normal camber setting and not have to beat up your wheel wells.
if you MUST have evo-x wheels.... have the mounting face machined 5 to 10 mm..
.......then they will work O.K. on an RA.
Offline
Aug 23, 2009, 11:17 AM
#42
I wouldn't classify rolling fenders and adding camber "alot of work". Proper fitment is making the wheels you like fit the car. Not buying sunken battleship wheels that look like **** just because they don't rub. As long as your toe is in check, you can get away with running on the higher side of the factory camber rating and not completly kill tire life.
Offline
Aug 23, 2009, 05:33 PM
#43
Quote:
Offline
Aug 23, 2009, 06:08 PM
#44
Drives: as fast as humanly possible.
Rolling fenders might not be alot of work but u can find a nice set of wheels for these cars w/o doin that. Like outty said if u must absolutely positively have them then go ahead but it is not necessary, those wheels are not cheap.
Offline
Aug 24, 2009, 12:56 PM
#45
ive decided im gonna go with 17x 8.5 wheels.
Allows for more tire which is what i want
Offline
Tags
09, 2009, bbs, evo, fenders, fit, forum, lancer, mr, ralliart, rolling, stock, weight, wheel, wheels  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
