Hi Everyone,
I have been researching high and low... and I am looking get the maximum wide wheel can fit the New Ralliart...
Stock Spec
PCD 5X114.3
SIZE 18X7
OFFSET 46MM
HUB 67MM
TIRES 215/45-18
Now form what I know....
9s is the wides we can squeeze with out rolling the REAR fender ON STOCK HEIGHT!!! but will need the
ROLL the REAR when LOWERING!!!
Here are some options I found
18x9s on a RA!!!!
18x9 +45 will = front maxed flushed and maxed flushed rears
Inner Clearance: 24mm LESS Outer Face Position: 26mm MORE
Tires: 245/40 18 no rubbing issues yet with stock height
***When Lowered [
WILL RUB on the REAR fenders with my calculation on bumps, dips, and pot holes and maybe driveways too]
SO ROLL THE FENDERS!!!!!!***
18x9 +36 will = front will poke about 1/2" and poke about 1/4" in the rear
Inner Clearance: 15mm LESS Outer Face Position: 35mm MORE
Tires:
235/40 18 no rubbing issues yet with stock height
***When Lowered [
***PROOF***
RRM Springs.***Hell Yea 9s baby!!
18x8.5 +38 will = fronts will poke out about 1/4" and rears will be flushed
Inner Clearance: 11mm LESS Outer Face Position: 27mm MORE
Tires:
225/45 18 if lower to prevent rubbing and cutting of the wheel on the fender
235/40 18 and 245/40 18 will rub a little on the fenders with my calculation on bumps, dips, and pot holes and maybe driveways too
***This fitment is too AGGRESSIVE with rolling the fenders***
***Now for the JDM look this will work for those dont know what i mean is the slammed drifter look in japan where all 4 wheels poke out just little past the fenders and the car has rock hard suspension setup and lower the car to about 1 1/2" before rubbing the fenders***
18X8.5 +44 will = fronts will be flushed and rears will need a 5mm spacer to be flushed
Inner Clearance: 17mm LESS Outer Face Position: 21mm MORE
Tires: 235/40 18 and 245/40 18 no rubbing issues with stock height
18X8.5 +45 will = fronts will be flushed and rears will need a 5mm spacer to be flushed
Inner Clearance: 18mm LESS Outer Face Position: 20mm MORE
Tires: 235/40 18 no rubbing issues with stock height
***Prefect fitment without spacer and stock height***Updated 5-31-09 "from what I can see"
Proof
New Rims and Tint!
18X8.5 +48 will = fronts will be flushed and rears will need a 5mm to be flushed [10mm spacer to be MAX flushed]
Inner Clearance: 21mm LESS Outer Face Position: 17mm MORE
Tries: 235/40 18 and 245/40 28 no rubbing issues with stock height
***Prefect fitment with 5mm spacer in the back***Updated 5-21-09
Proof
http://forums.evolutionm.net/2009-la...al-thread.html
18x8 +30 will = fronts will be poke out about 1/2" flushed and rears will be maxed flushed
Inner Clearance: 3mm LESS Outer Face Position: 29mm MORE
Tries:
225/45 18 if lower to prevent rubbing and cutting of the wheel on the fender with out rolling
235/40 18 will rub a little on the fenders with my calculation on bumps, dips, and pot holes and maybe driveways too
18x8 +40 will = fronts will be flushed and rears will need a 10mm spacer being maxed flushed
Inner Clearance: 7mm LESS Outer Face Position: 19mm MORE
Tries: 235/40 18 no rubbing issues with stock height
18x8 +45 will = fronts will be closer to being flushed and rears will need a 10mm spacer to be maxed flushed
Inner Clearance: 12mm LESS Outer Face Position: 14mm MORE
***FIT PERFECT with out SPACER***
Proof
Just ordered my new wheels and tires:)
My track wheels
18x8 +48 will = fronts will be closer to being stock and rears will be closer to being stock
Inner Clearance: 15mm LESS Outer Face Position: 11mm MORE
General Wheel Fitment Info...
Hub Rings
Make sure you get
hub rings for all aftermarket wheels don't want any weird noise, vibration or shaking...
make sure the wheel can fit oem tire pressure sensor ... for some reason not all aftermarket wheel fit it...
stay away from fake and cheap aftermarket light aluminum lugs... i have seen and have had lugs break off on a track day... if 2lbs matter to you get some reputable brands like work wheels and ray wheels that the ones i buy...
Rear space
Make sure it is hub centric... don't want any weird noise, vibration or shaking in the back!!!
TPMS
From TireRack
Thanks for the pm. I do show new sensors require a visit to the dealer for initialization. Haven't heard rotating causes an issue, but any new sensor needs to be programmed into the computer via a dealer visit. Typically its a 30 min labor charge.
Neal
If anyone else can give me more info on what they have or tried that will be great!!! TOGETHER we can make this the 2009 LANCER RALLIART WHEEL AND TIRES FITMENT THREAD
Evil
