Oct 24, 2009, 09:56 AM
#226
Personal Sales Rating: ( 0)
heres the pic.
Offline
Oct 24, 2009, 11:58 PM
#227
Gold Sponsor
Drives: 2009 Octane Blue Ralliart and AMS/NOS Energry Drink Drag Evo
What's the offset?
Offline
Oct 25, 2009, 12:19 AM
#228
Drives: 2009 Mitsubishi Lancer Ralliart
Quote:
Originally Posted by lookitznite
Hello all I recently just bought some new rims as some may know...
I'm currently running Enkei EDR09 18x7.5 +45 wrapped in 225/40 with the RRM springs
I'm currently looking to replace the new ones I just barely bought!
Want to replace with TENZO's DC-6 18x8 wrapped in 225/40 ...was wondering will it all fit with the rrm springs ? basicly im just changing the width by .5 i know i cant run 235 without running fenders...
I wouldn't do it. You have the same width tires anywys
Offline
Oct 25, 2009, 01:57 AM
#229
Drives: 2009 Lancer RA
With a +38 offset and 235s, I can run at stock height. If I am loaded or hit a deep bump, I will rub a bit, but not bad. I decided to have my fenders rolled anyway so that I can lower the car a bit, won't rub on dips, and can eventually run 245s.
Offline
Oct 25, 2009, 08:13 PM
#230
Drives: Lancer Aspire
i'm planning on running 18x8.5 +44 offset on this wheels
tires will be 235/40/18 , and car will be lowered by 1.2" front 0.8" rear with eibach pro-kit
anyone tried this setup ?
Online
Oct 28, 2009, 09:05 AM
#231
Quote:
Originally Posted by EricJ@AMS
What's the offset?
offsets for those wheels are like 38mm i believe or 33mm... do you think i can run them with my setup and not rub?
Offline
Nov 7, 2009, 06:21 PM
#232
Drives: 2009 RalliArt, 2008 Ninja
Before I get a new set of wheels for my RA, I plan on getting the RRM lowering springs (i.e., 1.5"F and 1.25"R drop). Based upon that, the only wheel that I have really liked on the RA is the Rota P45F. Here is a link for the wheels:
http://www.rotawheels.com/wheels.asp?wheelid=30
The offsets available for the Rota P45F in the 5 x 114.3 lug pattern are +35, +38, +45, and +48. What would be the best choice that would prevent me from having to roll the fenders, all things considered, if at all possible? Also, under what circumstances will spacers be necessary?
Thanks in advance!
Offline
Nov 7, 2009, 06:25 PM
#233
If they are +38, 225s should be fine. If they are +33, no way. I'm almost positive you'll need to roll.
Offline
Nov 8, 2009, 02:58 AM
#234
Drives: 2009 GG Lancer Ralliart
i'm planning to get a set of these Rota SVN's (Volk RE30 replicas) in a 18x9 +30 offset w/ a 235/40 tire and some BC coilovers dropped to prolly same drop height as the RRM springs later.
my questions are:
w/ stock height will they poke out hella?
how much rolling will i need to do if lowered?
or should i just settle w/ a little bit higher offset instead?
Offline
Nov 8, 2009, 02:29 PM
#235
Drives: Ralliart Lancer
if you were going to get those rims in that spec, you'll need coilovers and a bit of work. if you can, go the +36 offset and you'll just need to roll the rears
Offline
Nov 9, 2009, 01:31 AM
#236
^a +36 offset sounds a bit like bankaiup's exact setup. lol
but hmm i'm not too sure if they make that offset in these.
i'm gonna need to ask the people at wheeldude or something.
but thanks for some help though bro.
Offline
Nov 9, 2009, 07:04 AM
#237
Any thoughts or ideas?
Thanks.
Offline
Nov 9, 2009, 08:32 AM
#238
if your not looking to roll the fenders like you said then the less aggressive options like 18x8 +45, 18x8.5 +48, 18x8.5 +45 should be fine..
Offline
Nov 9, 2009, 03:19 PM
#239
Drives: Mitsubishi Lancer 2009 DE
Hi all !
Can someone tell me whether the stock '09 DE 16 wheels fit on the 09 ralliart ? I'm about to change my DE to RA and i may sell the 16 snow wheel/tire set with if i can't use it anymore.
Offline
Nov 10, 2009, 09:23 AM
#240
Thanks in advance!
First i would like to say thanks for finding those rims for me...I've been looking for those rims but didn't know they come in +45 offsets..as far as your setup... I have rrm springs on 18x7.5 wrapped in 225/40 no rub at all...so you can do it no problem with +45mm w/ rrm springs depending on size of the rims u do get.
Offline
Tags
2009, aftermarket, lancer, lowered, offset, put, ra, ralliart, rims, spacers, specs, tires, wheel, wheels, wider  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
