Feb 23, 2009, 08:02 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
2009 Ralliart - Brake Guide
**EDIT: INFO NEEDS TO BE VERIFIED AND/OR CORRECTED**
I figured that it's time for a reference thread so you all can all start collecting info about your brake system, aftermarket options, and where to find them. If you have more to add, post in the thread and I'll add it as I check in here. We're looking for part numbers, specs, cross-referenced applications, and sources. Thanks.
FMSI D866 - Front Pads
2001 - 2005 Chrysler Sebring (Coupe) - LX, LXi 6 cyl Front
2001 - 2005 Dodge Stratus Coupe 6 cyl Front
2001 Mitsubishi Eclipse Exc. Turbo 6 cyl. Front
2002 - 2007 Mitsubishi Eclipse Exc. Turbo Front
06/00 - 2001 Mitsubishi Galant (Exc. Sigma) V6 Front
2002 - 2007 Mitsubishi Galant (Exc. Sigma) Front
2004 Mitsubishi Lancer (Exc. Evolution) 2.4L Front
2003 - 2004 Mitsubishi Outlander Front
2007 Dodge Caliber
2007 Jeep Compass and Patroit
2008 Lancer
If you have brake part numbers to share (whether for pads, rotors, lines, etc) please post them here.
AXXIS/PBR front pad numbers:
MTS077483 (ultimates) 550*C/1022*F MOT (max. operating temperature)
MTS070554 (metal masters)
MTS070551 (deluxe)
Hawk front pad numbers:
HB435F.622 (HPS - 750*F MOT)
HB435Y.622 (LTS - intended for trucks, but it'll fit)
EBC front pads
D866 (Ultimax - OE grade)
DP21614 (Greenstuff 650*C MOT)
DP31614C (Redstuff 650*C MOT)
DP41614R (Yellowstuff - race 800*C MOT)
Porterfield
AP866 (front - available in R4, R4-E, and R4-1)
EXPENSIVE, but super high quality pads if you race, and they'll custom make pads in the other compounds they offer.
Rear Pads
FMSI not yet known. Someone needs to pull their rear pads and visually inspect the number on them. Application believed to be shared with 08 GTS Lancer, 04-08 Endeavor, and 01-06 Montero.
Rotors
I suspect that the Ralliart and GTS share the same front rotors as the V6 Galant, but I can't yet confirm it. I can confirm (via partsamerica.com) that the front rotors are the same as used on 07-08 Sebring, 07-08 Jeep Compass, 07-08 Caliber, 08 Avenger, 07-08 Patriot, and 07-08 Outlander.
Lines
Again, at least on the front, since the Ralliart uses the same calipers as the GTS, any SS lines for the GTS will work on the Ralliart, and it seems that the GTS is able to use the same lines as the 04-06 Ralliart, but I'm not 100% sure on that.
Offline
Feb 24, 2009, 09:55 AM
Personal Sales Rating: ( 0)
Drives: '07 subaru impreza, '04 Mazda RX-8, '99 Suzuki SV-650
I thought the calipers on the ralliart were larger than the ones from the gts. Do they still use the same size pads, and rotors?
__________________
"..in the year 3000, I had it all. Several friends, a low-paying job, a bed in a robot's closet. I envied no man. " - Fry
Offline
Feb 24, 2009, 03:16 PM
Quote:
My understanding is that the brake system on the Ralliart is the same as the GTS. I've verified that they do both indeed use the exact same pads and Mitsubishi's website verifies that they both use the same rotors. This means that both have the 04-06 Ralliart calipers (front) with a larger rotor.
Offline
Mar 12, 2009, 02:52 PM
Personal Sales Rating: ( 3)
Drives: 08' X GSR
Quote:
The 09+ Ralliart use Outlander 2-piston front calipers, so how can they share the same calipers with the single piston GTS?
__________________
08' X GSR
Offline
Apr 6, 2009, 11:00 PM
Drives: 03 bby EVO VIII-gone 09'ww RALLIART
Quote:
^exactly
__________________
TAI WILSON _ Mountain Pass Alliance
03'BBY EVO VIII -R.I.P.
09'WW RALLI//////////ART-prototype Crucial race suspension CRSSS02
Offline
Apr 10, 2009, 10:00 PM
Drives: 09' RALLIART //// SHADOW32 TINT, BLK WITH PREMIUM PACKAGE, T1R Test Pipe.
Yes Ralliart uses Outlander brakes as per the Dealer.
Offline
Apr 22, 2009, 07:53 PM
If that's the case, then please find out the FMSI number on the pads so this can be corrected.
Offline
Apr 26, 2009, 11:39 AM
2008 Mitsubishi Lancer
Drives: 09 WW Ralliart
Hey Otter, are the front pads on here 100% correct? I need to order some and just want to double check
__________________
Having the Christmas list in your sig is just like on the car. If you don't own the parts you show, it means you are a d**chebag ricer.
Quote:
Originally Posted by Mr Chef
But I know the car really well and the suspension is setup JDM safely so it's really controllable.
Offline
May 2, 2009, 07:23 PM
Well Otter seemed too busy to answer a simple question I guess. Double checked with EBC and they are the correct pad. Ordered a set of yellowstuffs
__________________
Offline
May 2, 2009, 09:23 PM
Personal Sales Rating: ( 1)
Drives: 2009 Lancer Ralliart, 1996 BMW M3
Anyone know if older EVO Brembo's will fit on the RA?
Offline
May 4, 2009, 07:36 PM
Anyone know if any Brembo's fit on the RA? whether there from the Evo or anywhere else. I've looked but not found anything.
Offline
May 16, 2009, 05:35 PM
Just an fyi - the EBC codes are wrong. Bought the yellow stuff and they do not fit. Hate to think the entire list is wrong...
__________________
Offline
May 18, 2009, 10:09 PM
Drives: 2003 Evolution VIII, 2009 Lancer Ralliart
Robi of Robispec and TheBrakeMan.com have come up with a very promising brake kit for the Ralliart. I am likely to be a guinea pig for said gear, as this car needs brakes like nobody's business. Robi overtook a particularly well-piloted Elise on Turn 5 at Laguna in his Ralliart *after* the Elise's nose dipped with this kit, on the inside. This is promising.
I will keep folks posted.
Cheers,
Adam
__________________
2003 Evolution VIII | AEM EMS, EvoIX MR Turbo, TurboXS DP/Catback and Helix Cat | Comp Cams 280 in/ex | AMS LICP and UICP w/Tial BoV | Exedy Twin Clutch | Shep Stage 2 Trans/T-Case /Ralliart LSD | ROBISPEC /// KW Clubsport Coilovers/Sway Bar/Whiteline goodies | AEM Gauges | Enkei NT-03 18x9.5 w/ 265/35-18 Nitto NT-01| Ferodo DS2500 pads / Centric slotted / dimpled rotors | Odyssey PC680MJT Mini-Batt | Walbro pump | 344.2 wHp/346.3 ft-lbs
4th Place, 2007 Evo Tuner Shootout - Street Class
Offline
Jun 2, 2009, 05:12 PM
for clarification the evo brembo's won't fit on the ralliart they have a different setup. the only company that i found that offers a big brake kit for the R/A is k sport. with 18" rims it's not recommended to go above 14" rotors and 13" are most common
Offline
Jun 3, 2009, 09:39 AM
Quote:
That's too bad Brembos don't fit.
Offline
Tags
07, 2009, art, brake, brakes, evo, forum, mitsubishi, outlander, pads, ralli, ralliart, rotor, spec, systems  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
