AMS, GST Boost Pill Difference?
Here are some boost plots for reference from a 100% bone stock 2009 Ralliart
"Factory Boost" = 100% bone stock 2009 Ralliart with stock tune
"Base Flash Boost" = 100% bone stock 2009 Ralliart with the GST Basemap which basically maxes out the stock boost solenoid at 100% duty cycle (with no pills removed or swapped)
"BoostPillUpgradeBoost" = 100% bone stock 2009 Ralliart with a boost pill upgrade and boost curve custom tuned.
- Bryan
- Bryan
Bryan,
Will the grade of gas you use effect the boost levels? Like if I only have access to 91 can I still hit levels of 22psi? I haven't done a ton of logging but I know in about 4 to 5 runs I did when I first installed the pill I would hit around 19 to 20 but i never saw levels of 21-22.
Could that be a stock BOV issue?
speedster07
Apr 23, 2013 08:25 PM
