Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Lancer Ralliart General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 3, 2009, 07:38 PM   #1
Personal Sales Rating: (0)
Drives: 2009 Lancer Ralliart
intake?
so i am looking at a intake for my 09 ralliart, and i have been looking around for the right one so what are some websites that you trust and have good parts and prices?
Offline
Old Nov 3, 2009, 08:36 PM   #2
Personal Sales Rating: (10)
Fourdoor's Avatar
Drives: 2010 Ralliart Sportback.
Do you want to get a custom tune or not?
If you don't want a tune right now, but would like a cone filter setup, do what I did and get a used EVO X MAF housing ($25 used, under $50 new from dealership), and a K&N cone filter. The filter will sit behind the stock battery, making a fan shield un-needed, and it is cheap compared to just about anything else out there. The stock EVO X MAF housing is the same internal diameter as the Ralliart MAF housing, so you will not require a re-tune, and a cone filter will fit right on to the EVO X MAF housing.
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Old Nov 3, 2009, 09:14 PM   #3
Drives: 09 ww ralliart
will that make more power than a drop in? more sound?^^^^
Offline
Old Nov 3, 2009, 09:24 PM   #4
Fourdoor's Avatar
Quote:
Should be more on both power and sound level... but I have not dyno tested a cone filter VS drop in panel filter so have no proof
Keith
__________________
Offline
Old Nov 3, 2009, 09:32 PM   #5
Personal Sales Rating: (7)
2007 Subaru Impreza
ambystom01's Avatar
Drives: Robut bear cavalry to the bearpocalypse
Are you sure that the intake doesn't change the tune at all? The reason I ask is even intakes that use the stock diameter for the MAF have been known to change the tune slightly. It's probably not enough to cause an issue, unless you're tuned to the max, but it's something to check, if only for knowledge sake.
__________________
This FAQ is a great starting point for new lancer owners
If you want my help, PM me, I won't post in technical forums lest I make waves.
Offline
Old Nov 3, 2009, 09:39 PM   #6
Fourdoor's Avatar
Quote:
I can only offer my experience here.... my tune maps have not been altered in the idle range, and my A/F ratio meter reads around 14.5:1 at idle most of the time (fluctuating around as you would expect). I am unable to log long term fuel trims, so I don't know if it is off slightly or not, but it has given me zero problems / drivability issues.
Take it with a grain of salt, this is just what I have seen on my car in my climate I don't have the stock battery to block air flow from the radiator fan, so I am using the Carbon Fiber air filter shield that I already had from when the filter setup was on my EVO X.
Keith
__________________
Offline
Old Nov 4, 2009, 02:47 AM   #7
NASTYxNAT3's Avatar
Drives: 2009 GG Lancer Ralliart
Send a message via AIM to NASTYxNAT3
^pics of your setup?
Offline
Old Nov 4, 2009, 07:13 AM   #8
Fourdoor's Avatar
Here is the EVO X MAF housing:
And here is the Filter installed on the MAF housing:
Keith
__________________
Offline
Old Nov 4, 2009, 08:13 AM   #9
Drives: 2009 RA
Is that carbon fiber piece your fan shield?
__________________
AMS SR intake [X]AMS BOV Kit [X]
UR Turboback
[X]
IVEY TUNED at 266whp/260wtq.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
