Quote:
Originally Posted by velocityhead
My method to remove those is to push from behind (when the car is cool). If you can reach your hand or a short screwdriver under/behind the radiator support, you should be able to feel them and push the center plastic piece out without damaging it from prying. I don't even need a screwdriver when I remove mine.
this is what u need to do, "push or hold" them from the underside and then unscrew them, whats happening when you try to unscrew them without doing this is they are just freely turning.
__________________
2009 Black Lancer GTS S&S, OEM EVO X hood , EVO X Recaro Seats, 2.4L Injen CAI, 18x8 MSR 045 225 40 HP Fierce tires, Carputer w/ 7" touchscreen running Centrafuse 1.47, Blacked out grille , Autopager 2 Way Alarm, Escort Passport 8500 X50 with ZR3 Laser Shifter, 20% Tint
