Oct 10, 2009, 10:04 PM
Personal Sales Rating: ( 0)
Drives: WW 2009 Lancer Ralliart
MAN DOWN!!! Second Casualty
Two weeks ago I was driving in the highway at about 65-75mph in normal mode (cruising in 6th gear obviously) all of a sudden the car went into 5th gear raking the RPM and slowing the car  , I was lucky I was not going faster and had both hands the wheel otherwise I could have easily lost control of the car or the car behind me could have slammed into me.
As I was trying to figure what had just happened I slowed down and noticed the car would not take 6th gear I tried to do it manually and nothing happened. As I was slowing down to reach the emergency lane the car jumped from 5th to 3rd and then again from 3rd to 1st gear. I stopped and no warnings light had gone on so I figured what ever it was it was fixed as I accelerated back into the highway the it was still doing the same thing when I manually changed gears It went from 1st to 3rd. For some reasons it did not want to take 2nd, 4th or 6th gears. I stopped again, turned the car off and turned it back on and everything was back to normal.
However, since then the problem has happened 2 more times , the last time been last night. It always happens while I’m cruising at high speeds in normal mode, not in traffic. Each time it seems as if the gears get stuck inside the tranny or something and I have to stop and turn the car off to make it go away. It is really annoying and dangerous as it happens unexpectedly. The weirdest part is that no warning light come on and there is no indication from the car that something is wrong.
YESSS!!!! This is the same problem hernandez had back in April. Just wanted everyone to know you might be next!
The first problem I had with the TC-SST happened a month after buying the car. It only had 500 miles on it but back then the Transmition problem light came on. I was lucky the dealer change the car for a new one back then. This car is a little over 14k now, I dont know if I will be as lucky this time.
I only have two things to say F*** THIS CAR!!! and F*** Mitsubishi!!!! Sorry no offense to anyone...just needed a place to vent.
Offline
Oct 10, 2009, 10:46 PM
So one of the clutches is having issues, did you get it repaired?
Offline
Oct 11, 2009, 08:09 AM
Drives: 08 gts , 07 outlanderxls ,09 RA
has anyone ever "played around" with your tcu or ecu ? ?
are your paddle shifters overly sensitive ?
my paddles do not take much pressure to shift.
i have accidentally up-shifted by just bumping the + paddle before.
never accidentally down shifted though.
Offline
Oct 11, 2009, 04:12 PM
Drives: 09' Ralliart
Sounds like the evens side of the tranny is f'ed up.
Offline
Oct 11, 2009, 04:17 PM
Drives: 2009 Ralliart Sportback
Sounds to me like the tranny computer is mucking up on one group of gears.
Get it to the dealer ASAP.
__________________
Cheers,
John
Offline
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
Scary
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Oct 11, 2009, 04:27 PM
Drives: 2004 Mitsubishi Lancer ES
I would keep the bashing until you go to the dealer. You're obviously still covered under warranty so I would take the car back. If they can't fix the problem then you can start getting upset.
Let us know what happens at the dealership.
__________________
Josh
2004 Mitsubishi Lancer ES:
Amsoil 0W-30
Amsoil Fluids throughout
Custom Short-ram w/ Amsoil Nanofiber
OBX Headers w/ original exhaust
Offline
Oct 11, 2009, 05:09 PM
Drives: 2009 RA
I never use flappy paddles EVER!!! I think its the dumbest thing they ever made in a car. Why not just use your shifter.
i wonder if this is just a thing with people who use the paddle shifters. Did hernandez use paddle shifters as well.
Offline
Oct 11, 2009, 06:03 PM
You sound like jeremy clarkson..
Offline
Oct 11, 2009, 11:59 PM
What does he need to do? Put plastic on the paddle shifters for protection?
Cmon now they put those there on purpose and are meant to be used when needed.
__________________
Josh
Amsoil 0W-30
Offline
Oct 12, 2009, 02:11 AM
2008 Mitsubishi Lancer Evolution
Drives: Lncer Evolution X GSR
So did you take it in to the Dealer? Do you have any Mods
Online
Oct 12, 2009, 08:11 AM
Drives: 2009 Lancer Ralliart (Rotor Glow Orange)
Quote:
+1 -- but wouldn't losing the even side screw up reverse too (because reverse use some of the forward gears), or does reverse just use the odd forward gears?
__________________
Brian
Offline
Oct 12, 2009, 08:48 AM
Quote:
I think what you're talking about is the Evo X GSR 5-spd manual? That might share 2 drive gears + an idler to make reverse.
The TC-SST 6spd has a real reverse gear installed, fortunately for this guy, on the odd gear shaft. So if his evens are screwed up, he should still have reverse coming off the odd shaft.
Offline
Oct 12, 2009, 09:21 AM
Personal Sales Rating: ( 10)
Drives: Evo VIII
that sucks man, go to the dealer and trade that lemon in
Offline
Oct 12, 2009, 02:01 PM
Drives: 2009 MITSU RALLIART, 1969 Ford Mustang 302
Had the the exact same thing happen to me, any mods get em off and prepare for a new trans.
__________________
(X) Ultimate Racing Exhaust
(X) Ultimate Racing IC Piping
(X) Ultimate Racing Downpipe
(X) Ultimate Racing Testpipe
(X) Forge Diverter Valve
(X) Glowshift Boost Gauge
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
