Oct 7, 2009, 09:41 AM
Personal Sales Rating: ( 0)
2009 Mitsubishi Lancer
Drives: 2009 Mitsubishi Lancer RalliArt
Factory turbo timer
I dont know if anyone noticed but when shutting off the car, theres a 2-3 sec delay before shutting down. Is it possible the the RA has a factory turbo timer and if it does are we able to adjust the time to allow the turbo to cool down before shutting down. Figure a good minute than shutting down or an aftermarket turbo timer is needed. I always give the car a good 2 minutes to cool down from a long drive than shutting down.
Offline
Oct 7, 2009, 09:42 AM
Personal Sales Rating: ( 7)
2007 Subaru Impreza
Drives: Robut bear cavalry to the bearpocalypse
No, this has been discussed before, that's not a turbo timer.
Offline
Oct 7, 2009, 09:44 AM
K thanks, Im a nooob to the forum.
Offline
Oct 7, 2009, 09:56 AM
Personal Sales Rating: ( 55)
Drives: corolla
Quote:
Look, you don't have to allow the turbo to cool down if you didn't race the engine prior to coming to complete stop. Allowing the car to cool down 2 mins is waste of gas, period!! I have a APEXi turbo timer, I put in auto mode, it will basically check and see if the engine needs to be delay shut off, most of time it nevers delay shut off, only when I rev it while trying to park in the garage then it will delay shut off for no more than 30 seconds.
__________________
4WHEELSLIDE TUNED
ROBISPEC TUNED///
Offline
Oct 7, 2009, 10:25 AM
Drives: 09 Ralliart
It is the transmission clutches and gearing disengaging.
__________________
Mitsubishi, Nissan, Mazda, Subaru
The Last of the Japanese performance brands forging ahead into the millenium.
Offline
Oct 7, 2009, 11:58 AM
Personal Sales Rating: ( 4)
Drives: Evo MR
lol.. i thought it was a turbo timer as well :P
Offline
Oct 7, 2009, 03:46 PM
Drives: ww 2008 lancer es cvt - s&s pckg
the dood at the mitsu dealership says theres no need for turbo timing in the new evo/ra's. thats not correct is it? cuz i think hes crazy :X
Offline
Oct 7, 2009, 04:02 PM
Drives: 09RA - GG
Unless you peak boost down your street, and up your driveway. There really is no need to get a turbo timer for the X/RA...I forget where I read this from...I'll try to find it somewhere.
__________________
GTS + 'Roids = 09RA
Quote:
Originally Posted by IdriveRA
"is that an evo?"
"Nah it's just a RalliArt"
Offline
Oct 7, 2009, 04:55 PM
Personal Sales Rating: ( 1)
Drives: WW 09 Lancer Ralliart
every where i go its always peak boost.. from light to light, through the car wash, up my driveway into the garage. Then i instantly shut it off before i even put it in park.
Quote:
__________________
(x) Change in the ashtray
(x) a pack of gum in the cup holder
(x) performance wiper fluid
(x) oil change
(x) another pointless list nobody cares about
Offline
Oct 7, 2009, 06:23 PM
2007 Subaru Impreza
Quote:
He's right, unless you're really really hard on the motor, it's unnecessary.
Offline
Oct 8, 2009, 07:51 PM
Drives: 09 WW Ralliart
^ exactly what i was going to say. and even if you are, and you shut it off with very high engine/engine bay temps, there is an after-run fan setting that will engage your cooling fans automatically even while the car is turned off, hence that little sticker on the cowl that says "Caution, electric fans may come on at any time...blah, blah..." you know the one.
__________________
03 LB Lancer OZ: totalled 06-2005
09 WW Lancer Ralliart: bought 05-2009
Back in the saddle again...
Reason: arrow
Offline
Oct 8, 2009, 09:11 PM
Personal Sales Rating: ( 10)
Drives: 2010 Ralliart Sportback.
Another factor in not needing a turbo timer is running full synthetic Mobil 1 oil. In the bad old days of oil pumped up out of the desert sands oil was MUCH more likely to coke up on the turbo bearings if you shut down right after some high performance driving. Even then if you didn't drive too much like a jackhole you were fine.
Keith
__________________
2010 Lancer Ralliart Sportback... From stock to modified as follows in less than a week!
Buschur Racing FMIC, upper IC pipe, and lower IC pipe with EVO X BOV. AMS cat back exhaust, mini battery kit, and MAF housing from EVO X,Buschur Air filter mounted to EVO X MAF housing. Forge WG actuator, Ultimate Racing high flow cat.
Triple gauge pod with Wide band A/F ratio and boost.
Offline
Oct 8, 2009, 09:13 PM
Drives: Evo VIII
Turbo timers are not as necessary nowadays. Most timers wont even keep the car on unless you were running the car hard just before parking.
__________________
Otters are really stupid animals.
Offline
Oct 8, 2009, 09:21 PM
Drives: 05 mitsubishi lancer evolution Vlll
really if it was nessecary and needed on the car they would have put it on from the factory.... but then again, it says in the owners manual after hard runs to let the car run for a 1-2 min
Offline
Tags
02, 09, adjust, boost, car, evolution, good, harness, mitsubishi, ralliart, shut, shutting, timer, timers, turbo, turbo timer  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
