Go Back   evolutionm.net > Lancer Ralliart Forums > 09+ Lancer Ralliart General
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 24, 2009, 06:34 PM   #1
EvoM Moderator
Personal Sales Rating: (26)
joedr's Avatar
Drives: 09 RalliArt; Lancer Evo IX MR; 1999 Honda Civic
Send a message via AIM to joedr Send a message via MSN to joedr
Thumbs up RA seat rails and Evo X seats
Do the RA rails fit the Recaro seats?
I just bought some Evo X seats and the former owner installed them on another car. He pulled the 4 flanges that hold the seat to the chasis off the seat rails to adapt some for the other car that had them. At the end, the seats are pretty much flat on the ground without the flanges.
What will be the easiest?
1. Swap the seat rails off from the RA to the Recaros and viceversa.
2. Remove the flanges off the RA and weld or bolt them to the Evo X rails.
I guess that the easiest way to do it is to visually check the rails themselves, but I did not have a chance yet.
__________________
Thanks!
-Joed
EVO MR 2006 - 403.08 WHP / 356.68 TQ - FPGreen // BR Stages 1, 2 & Race I/C // Nisei LICP // PTE 780CCs // Walbro 255 hp pump // Blitz iColor @ 25 PSI // LC-1 WB // GSC S2 // Defi BF w Gruppe-S Panel
Offline
Old Sep 24, 2009, 06:48 PM   #2
Personal Sales Rating: (1)
Drives: 09 Ralliart Fp Red Ordered
Just use your stock RA rails.
Offline
Old Sep 24, 2009, 07:09 PM   #3
EvoM Moderator
joedr's Avatar
I knew they looked very similar!
Any idea about the torx size for the rails bolt?
Thanks a lot for the prompt response!
__________________
Thanks!
-Joed
Offline
Old Sep 27, 2009, 11:19 AM   #4
EvoM Moderator
joedr's Avatar
Not straight forward swap!
The passenger side needed to remove a bracket that are held by some rivets. After removing that bracket, the RA rail bolt right away.
The driver side rail can not be swapped. Or at least not w/o major changes. I ended up using the Evo X rail and bolt the flanges that go to the chasis into the rails.
I got no SES or airbag code on the car after the swap.
So, for a true plug-n-play... Get the Evo X seats with all brackets and rails. Everything should bolt right in.
__________________
Thanks!
-Joed
Offline
Old Sep 27, 2009, 12:13 PM   #5
Personal Sales Rating: (0)
2008 Mitsubishi Lancer
Drives: 09 WW Ralliart
Quote:
Thanks for mentioning this part, I just bought an Evo X Sparco bracket without knowing if it would match the same
__________________
Having the Christmas list in your sig is just like on the car. If you don't own the parts you show, it means you are a d**chebag ricer.
Quote:
Originally Posted by Mr Chef View Post
But I know the car really well and the suspension is setup JDM safely so it's really controllable.
Offline
Old Sep 27, 2009, 01:55 PM   #6
EvoM Moderator
joedr's Avatar
Hope that I posted this before you order something 4 hrs away on mods to get it fit. Good luck!
__________________
Thanks!
-Joed
Offline
Tags
09, 2006, 99, civic, evo, honda, horsepower, mr, rail, rails, ralliart, recaro, seat, seats, size
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
