LancerReplay's 2010 Rotor Glow GTS
Hi Im new to this forum from California and I just joined today 2/14/13. I would like to post some pictures of my Rotor Glow. The iPad Mini dash mod was modded at Soundman Car Audio. They posted the video of the build on their Youtube channel.
Performance Mods:
-Magnaflow Catback Exhaust
-RRM SRI V2
-RRM Light Weight Pully
-RRM Timing Controller
Exterior Mods:
-Front vinyl blackout
-OEM Black DE front grill with Mitsubishi Emblem painted Rotor Glow
-RRM CF front lip
-RRM CF Spark Plug Cover
-RRM CF Radiator Cover
-RRM side mount plate
-LED Plate Lights
-Tint Windows (Suntek CXP 18% Rear, Suntek CXP Clear 80% fronts)
-LED Dome Light
-LED Map Light
Sound System:
Featured on Soundman Car Audio on Youtube.com / Amplified on Revision3.com
"iPad mini installed in Lancer GTS, modded EVO Dash, Mitsubishi - Amplified #90"
-iPad Mini (64gb) dash Side Slider (Featured on Soundman Car Audio on Youtube / Amplified on Revision3)
-Hertz DCX 165 Speakers
-Hertz DSK 165 Speakers
-Alpine Subwoofer Type-E
-Alpine MRX-V70 Amp
-iStreamer
-ACR-1 Audio Control Volume Knob for iPad Mini
-Audio Control Matrix
Suspension Mods:
-Megan Coilovers
-Progress Rear Anti Sway Bar
-RRM Front Strut Bar (Painted Rotor Glow)
-RRM Rear Upper Strut Bar (Painted Rotor Glow)
-RRM Lower Tie Bar set
-RRM Lower Truss Bar
Wheel & Tire:
-Rolled Fenders
-19" Tenzo-R Cuzco 19x8.5 + 45 Matte Black with color matched stripe (Rotor Glow)
-Nankang NS-II 245-35-19 Tires
Performance Mods:
-RRM SRI V2
Exterior Mods:
-RRM CF front lip
-LED Plate Lights
-LED Dome Light
-LED Map Light
Sound System:
-Alpine MRX-V70 Amp
-iStreamer
Suspension Mods:
-Megan Coilovers
Wheel & Tire:
-Rolled Fenders
Ok so I had some more work done to my car. Here are a few pictures.
Here is the Evo X hood that is now painted Rotor Glow. The paint came out great very happy with the results after I saw it. Really makes the car look good. Also the cf lip is not on I will have to fix it and might put it back on I kinda like the look of it right now.
I went to RRM on WED and added a few new things:
Here is another picture. I got the piggyback installed as well as a cf engine cover.
My RRM header with the PZEV adaptor
I went to Soundstations the next day after RRM and had some extra stuff done. They made a better mount for me than what I had originally done which was great.
I also had two new switches added. The left one is a reset switch for my ipad mini (Sometimes the mini wouldnt connect correctly so instead of restarting my car to make it connect properly i got this switch which helps allot. Soundman did a good job when I first got the ipad dash and audio set up. Its something about how the mini connects which is what was causing some issues).
The button on the right is a toggle switch. With this switch I can chose from the ipad mini or switch the connection to the aux port so now I have a way of connecting another source of audio through my speakers instead of just the ipad mini
This is my Sirius antenna on my left side of dash. Connection is perfect.
In this picture you can see the sirius antenna comming through the upper left. Since i have no use for that spot, the sirius antenna is a good choice for it to make it useful. To the upper right you can see a new Aux port. I prefer this type of port. Below it is just the monster aux cable.
And finally heres examples of what I would use the new Aux port for:
This is my sirius I dont have it mounted since I dont leave it in my vehicle which means I can always take it out when im not in the car.
And heres my other ipod
So thats it for now.
New updates
It has been a while since I have updated my progress thread. I will list all current mods and I will also post up some photos right afterI list my current mod list.
My current mods are:
LancerReplays Mods
Exterior
- Front vinyl blackout
- OEM Black DE front grill with Mitsubishi Emblem color matched Rotor Glow
- Trunk Emblems Plasti Dipped Black
- RRM Side Mount Plate
- Carbon Fiber License Plate Frame.
- OEM EVO Hood (which I got color matched)
- 3 inch Carbon Fiber Antenna
- LED License Plate Light
- Tinted Side Markers
- Tint Windows (Suntek CXP 18% Rear, Suntek CXP Clear 80% fronts)
Engine Mods
- RRM SRI 2.4L
- RRM Piggyback Calibrator
- RRM Timing Controller
- RRM Carbon Fiber Engine Cover
- RRM Carbon Fiber Radiator Plate (Will need to make a hole for air but picture is with it on as is currently have the oem on)
- RRM Carbon Fiber Spark Plug Cover
- RRM Aluminum Crank Pully 4B12
- RRM 2.4L RRM 4B12 Header
- RRM 2.4L PZEV Header Adaptor
- Magnaflow Catback Exhaust
Interior
- LED Dome Light
- LED Map Light
- LED Trunk Light
- SickSpeed Panorama Rear View Mirror
Sound System
- iPad Mini (64gb) dash Side Slider (Featured on Soundman Car Audio on Youtube.com/ Amplified on Revision3.com)
- Hertz DCX 165 Speakers
- Hertz DSK 165 Speakers
- Alpine Subwoofer Type-E
- Alpine MRX-V70 Amp
- iStreamer
- ACR-1 Audio Control Volume Knob for iPad Mini
- Audio Control Matrix
- Sirius Radio Antenna
- New Single Aux Port installed next to existing L & R aux port
- Reset Switch for iPad Mini
- Toggle switch to switch from iPad mini connection to Aux Port
Suspension Mods
- Megan Coilovers
- Progress Rear Anti Sway Bar
- RRM Front Strut Bar (Painted Rotor Glow)
- RRM Rear Upper Strut Bar (Painted Rotor Glow)
- RRM Lower Tie Bar set
- RRM Lower Truss Bar
Wheel & Tire
- 19" Tenzo-R Cuzco 19x8.5 + 45 Matte Black with color matched stripe (Rotor Glow)
- Nankang NS-II 245-35-19 Tires
- Rolled Rear Fenders
- Carbon Fiber Matsu Tire Stem Valve Caps (Currently using)
- Sickspeed Black Tire Stem Valve Caps
Pending Install
- Hella Supertone Horns (Color Matched Rotor Glow "Pending Install")
- 4G69 Throttle Body
- HL Rear Diffuser (Needs Paint and Fiber Glass Work)
On Order
- Carbon Fiber Dash Trim Kit Complete Set 67 Piece.
- RRM Carbon Fiber Fuse Box Cover
LancerReplays Mods
Exterior
Engine Mods
- RRM SRI 2.4L
Interior
- LED Dome Light
- LED Map Light
- LED Trunk Light
Sound System
- iStreamer
Suspension Mods
- Megan Coilovers
Wheel & Tire
Pending Install
On Order
1) I have plasti dipped my rear trunk emblems black. Im going with the whole Orange and Black look with some Carbon Fiber.
2) I bought some Matsu carbon fiber tire stem valve caps from ebay and also some sickspeed tire stem valve caps.
Im currently using the Matsu carbon fiber tire stem valve caps
3) I bought a 3 inch carbon fiber antenna.
4) I have a 4G69 Throttle body but have yet to install it.
5) I bought a Sickspeed Panorama mirror. It works great.
6) I bought some carbon fiber license plate frames.
7) I also tinted my side markers. The tint looks blends well with the look I'm going with.
8) I bought a LED light for the inside trunk and also Hella Supertone Horns. I also color matched the horns Rotor Glow.
9) I also bought a HL Rear diffuser from a member in CA. I have it but still need to get it painted. Here is a example of what it is supposed to look like if you have not seen one.
10) Finally I ordered carbon fiber interior trim. I went with this since I wanted to try something different from carbon vinyl. Im still waiting for them to create the carbon trim pieces. I went with the complete kit 67 pieces. I wont use all but have a idea of what parts I really want to use.
So to update my progress thread heres a few things new updates to the lancer.
1) New Carbon Fiber interior trim pieces.
Heres a few photos of that. Even though its 3m I still like how the CF looks.
2) I went to SoCal to have my Lancer tuned by Rick at RRE Road Race Engineering.
Before doing that I had to remove my RRM Timing Controller and RRM Piggyback.
The Lancer wont hit any amazing high HP numbers but Im happy with how the car feels right now after the tune.
3) I also went next door to RRM to pick up a CF Fuse Box Cover.
Makes the engine bay look nice
4) I got my HL Rear Lip. I had to go and get it repaired, painted and installed. The lip that I bought from someone was in bad shape but I'm happy that the shop was able to do such a great job at putting it together.
5) I also got my R1 Concepts brakes Premier series, with Stoptech pads and Posi Quiet pads.
6) Heres a few photos of me and my crew.
I will keep updating this more as soon as I get some more mods in. In the time being I will just have to keep my car clean.
Thank you I just updated my post with the dyno sheet for the tune I got at RRE.
I actually got the OEM Hood from a member on a different forum.
Thanks Actually the antenna is just for looks, I'm not 100% sure how good it works since I don't have the old radio in the car. My only source of audio is the iPad mini and my Sirius radio. I added the CF one to remove the big oem antenna.
