Questions about upsize the rim of 04 Ralliart
Old Apr 23, 2012, 12:28 PM
nshen43's Avatar
Hi guys,
I've got a 04 Ralliart. I'm going to change my wheel size from the original 16" to a 17" one. I have a few questions about the ABC of tire & wheel:
1. For the bolt pattern, the original is 5x113.6, but I saw a lot of 5-bolt-pattern wheel with a parameter of 5x100/113.6 (from amazon). I suppose that would be two options of the bolt pattern, but there wasn't a chance to select it after I entered the product page. Can I trust such kind of spec?
2. I can't find the original width of the rim. My original tires are P205/50R16. I think P205/45R17 could be the best in order to avoid change the tire diameter and keep the tire in the same width. Generally, almost every 17" rim has a width of at least 7". I'm not sure that a 205 mm wide tire is good on a 7" wide rim, because I found a chart said 205 mm wide tire is good for a 5.5" wide rim.
3. BTW, do you think how much fuel efficiency I'll lost, if I change the 205 mm wide tire to 225 mm one? I find the 225 mm wide tire are more safe for the 7" wide tire. If I don't lose too much fuel efficiency with increase the width of the tire, I'll go a 225 mm one.
Thank you very much!!
Old Apr 23, 2012, 01:02 PM
roblaza's Avatar
1: Our bolt pattern is 5x114.3
2: Original width I believe is 6.5''. You can run a 215/40/17 without issues on a 7, or even 7.5'' wide wheel. 205/45/17 will look too beefy....
3: the difference will be miniscule.
I have 17x7.5'' rims with a +40mm offset, 215/40/17 tires and there is no rub...not even a little.
Proof:
Old Apr 23, 2012, 01:10 PM
nshen43's Avatar
Proof:
The offset information is very useful for me. Thank you very much for all your answers!
PS. My bad the bolt pattern I mentioned on Amazon was 5x100/114.3. Never mind. I'll get some with 5x114.3.
Old Apr 23, 2012, 01:49 PM
EvoM Super Moderator
lanzerralliart's Avatar
All you guys with black rims are making me want to paint mine more and more , fatherco , roblaza, to name a few ..... Thanks guys like I don't already have enough **** on my "want list"
Old Apr 23, 2012, 01:50 PM
nshen43's Avatar
Proof:
What about this? There are 10 bolt holes on a 5x100/114.3 wheel. Five of them are 5x100 and the others are 5x114.3. Is this true?
Old Apr 23, 2012, 02:13 PM
roblaza's Avatar
Yup!
Old Apr 23, 2012, 02:26 PM
Raikiri's Avatar
black wheels... pssshhh!!!
Old Apr 23, 2012, 02:30 PM
roblaza's Avatar
You love it. Lol I'm actually going to go back to a 16" rim and ditch the 17" black ones. What colour for the 16"s is yet to be decided. Lol
Old Apr 23, 2012, 05:38 PM
2006_RA's Avatar
Proof:
OEM rims are 16 x 6 with a 46 offset that would be +ve.
Old Apr 23, 2012, 07:18 PM
roblaza's Avatar
I stand corrected! lol
It's proving to be very difficult to find a 16x8 rim within the specs that Im looking for, and our bolt pattern. There are some, but none that really peak my interest. The ones that I do like come in a 16x7, and I'm unsure as to the offset I can run.
I've seen that a 16x8 with a +35 offset works pretty well, which would lead me to think that a 16X7 with a +20 ish offset would be good to go aswell...so here is my question:
With a 16x7, what is the absolute maximum offset can I run with a 215/45/16, keeping in mind that I'm rolling my fenders in the near future to accomodate.
Old Apr 24, 2012, 05:57 AM
myra13's Avatar
Q? Would a 18" rss 18x7.5 with 215-35-18 tires fit on 2004 lancer ralliart... ??
Old Aug 2, 2012, 08:21 AM
manolo2011's Avatar
i use to ran 215/40/17 on tein s-techs and 17x7.5... just a little rubbing but after putting new OEM SHOCKS no rubbing at all
Old Apr 19, 2020, 11:38 AM
Fred Evans's Avatar
Proof:
Are you on stock suspension?
dave_evolvix
Mar 31, 2016 09:22 AM
TheChampiYon
Nov 10, 2015 05:48 PM
JMusto0223
14
Sep 10, 2015 10:49 AM
BLKRalliArt04
136
Apr 16, 2015 05:15 AM
lookitsjohnny
Mar 16, 2012 01:25 PM
Quick Reply: Questions about upsize the rim of 04 Ralliart
