Aggressive Wheels on 2004-2006 Lancer
Old Jan 4, 2012, 03:00 PM
  #121
deathsythe99's Avatar
ok so i checked that website and this is what i found
http://www.nlmotoring.com/ProductDet...8102N&CartID=1
question i still have is do i need hubcentric rings still??and what size should i get?? i know nothing on wheels so help me out here guys.
Old Jan 4, 2012, 03:46 PM
  #122
Drew314's Avatar
Yes, you need these...
http://www.nlmotoring.com/product-p/...slash-67.1.htm
Old Jan 5, 2012, 04:25 AM
  #123
Originally Posted by Drew314
thanks you helped me alot . i was thinking of color i kind of want gold but i also want the c.black. what do you guys think i know its personal preference but what do you guys think?
Old Jan 5, 2012, 10:28 AM
  #124
keithislegit's Avatar
Dunlop Direzza 101's are fairly thick tires... Do you think 8-10 mm spacers will work in the back? Or is that a little to much. My tire's a 215/50/16 on a 16x8 +38 offset. But if people say 5 mm is all I need, I'll get that instead. Does anyone know a place where I can get cheap spacers?
Old Jan 6, 2012, 02:41 PM
  #125
do you think i will need spacers?
Old Jan 6, 2012, 02:50 PM
  #126
I mean, if you're stretching tires with a 205 on a 8" rim, I think a 5 mm spacer is all you need? I'm not sure but I'm trying to look for spacers. I'm not sure if I need a 10 mm or smaller.
Old Jan 6, 2012, 07:42 PM
  #127
i dont get how the tire stretching thing goes. the rim would be 8.25 wide.
Old Jan 7, 2012, 09:48 AM
  #128
I mean, a 205 will have a minor stretch on a 8" and with another 1/4 inch it's going to stretch even more. With my 215 on an 8" there's a very SLIGHT stretch but it looks nice in my opinion. A perfect size that would find on an 8" is a 225, but you'd have to roll your fenders and use huge spacers. So the best thing to do is go with a 215 tire and use 5-10 mm spacers. I guess that's what I'm going to do. I'm testing it out right now, my 215/50/16 tire on a 16x8 +38 offset can't even fit on the back without spacers. The front isn't so bad as the car is at stock height right now, but when I lower it I think I might need like a 3 mm spacer. I'm not sure if I need the spacers with the studs or the ones without it. That's what I'm trying to find out.
Old Jan 7, 2012, 12:12 PM
  #129
so i will plan on buying some 5mm spacers for front and back. what do you mean it wont fit on the back?
Old Jan 11, 2012, 03:12 PM
  #130
You can do that also, and roll your fenders. When I say doesn't fit, I mean, if I put on the wheel, the tire rubs on the strut thing? I don't know how to explain it, I'll take a picture sometime later on, but it covers the rear struts. My tire rubs against it and my rim would hit it.
Old Jan 18, 2012, 08:42 PM
  #131
lanceresx9's Avatar
hey guys I'm looking at a set of Rota IK-R either a 17x9+35 or a 17x9.5+45 help on what will fit and what tire to get I'm am lowered on megan racing coils and am willing to camber a lot and pull and roll fenders just need some help on the measurements.
Old Feb 24, 2012, 12:47 PM
  #132
No clue if that would fit, probably would be to big... but I'm not sure.
Old Feb 27, 2012, 05:21 PM
  #133
ok guys got my refund so far on my list for wheels is
xxr 527's 17 x 8.25 (gold)
neo chrome open end lugs (what do you guys think?)
hub centric rings 73.1/67.1
need your input on how things will fit before i go and spend $600 thanks.
Old Feb 27, 2012, 05:25 PM
  #134
Raikiri's Avatar
why would you need the hubcentric rings? I have this exact same setup on my car right now... no spacer in the front and 3mm in the back
EDIT:
btw... i prefer closed ends
Old Feb 27, 2012, 05:35 PM
  #135
EDIT:
what offset? i was thinking +35
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
