Aggressive Wheels on 2004-2006 Lancer
#301
tyson you're from van?
I ran 17x9 +15 with pulled fenders, but they were pulled hard. I also ran 17x9.5 +10, which is my current setup. The fenders literally beat to **** and aggressively pulled. Going with a different setup instead of stretch tires now. Its no fun driving around in those
soo when you say "aggresively pulled" what are we talking here?
and realistically then i can run a 8with some rubbing?? cause i can live with that a bit im used to it haha.
as an idea this is what i used to daily all over the lower mainland.
i was running 16x9 16x7.5 et 20
soo if i cab get away with a 17x8 ill be happy cause i plan on going lowwww
#303
hmmm interesting. okay soo to keep the body lines the same a clean i will just go for 8s all around and ill be getting some bc racing coils to add lows to the car
mind this will all be taking place in the down season.
soo she will be sitting all pretty for next spring and all the car shows.
#305
For those Non-believers
What I have here are the evo BBS rims 17x8 +38 on 215/40/17 General Tires. As far as I'm concerned, these tires are perfect and I don't feel any rubbing. I did not need to roll the fenders in the back which saved me even more money. For anyone that ever doubted this setup, I hope this changes your mind. I've been doing a lot of reading prior to buying these rims and a perfect opportunity came so I made the purchase. I wish I had a better camera, but the iphone4 is all I have now.
#306
Very nice NorCal , those look perfect , how the car should of came from the factory. Did you need to roll the fronts?
I thought most knew that the evo 8-9 rims fit with the 215/40 series tires but for those that don't here are pics. Although I think for anyone that does some spirited driving would want to roll the fenders. That looks pretty tight, and all tires have different shapes even if the size is the same and I wouldn't want to risk scratching the rims.
#308
Even after from doing all my reading, I barely found any pics with evo rims on RAs. Only pics are from guys from PR and not much was said about it. I was very surprised to find no rubbing issues, the offset must be perfect for those wheels. These rims stick out very nicely on the side, 17x8 is definitely a nice upgrade from 16x6.
#309
Update: currently in the process of moving places. When my car is full of stuff, still no issue of rubbing; however, when I was driving two of my friends, the side he was sitting on was rubbing the fender. It wasn't much but enough to know I need to roll those fenders by just a little bit. Otherwise i would never be taking more than one person haha.
