Aggressive Wheels on 2004-2006 Lancer
Old May 5, 2012, 06:06 AM
  #286
nc_bboy's Avatar
Originally Posted by 213ralliart
do i need spacer .. im running 215 35 18 18x7.5 the ride rough though
What offset do you have? Also the ride will seem rougher then usual due to the very small side wall you have 215/35.
Old May 5, 2012, 11:46 PM
  #287
pnoy_RA06's Avatar
checkin out this 17x7.5 +45 (215/40/17 tires) wheels, gonna be rolling on s.tech springs. do i need any spacers? or get any of my fenders rolled?? thanks.
Old May 5, 2012, 11:59 PM
  #288
Raikiri's Avatar
i dont know the answer but before posting at least read through the thread as im fairly sure its been asked multiple times
Old May 6, 2012, 07:26 AM
  #289
nc_bboy's Avatar
Yeah it's been answered a lot. I answered it a few pages ago because I was running 17x7.5 +45 with 215/45R17. I know we want people to search but I'll answer it one more time.
You have to run atleast 3mm spacers to clear the strut housing. If you want flush look at the previous page and you'll see what I recommended. Hope it helps
Old May 8, 2012, 12:59 AM
  #290
213ralliart's Avatar
offset are 45mm
Old May 8, 2012, 03:27 AM
  #291
nc_bboy's Avatar
offset are 45mm
Oh ok, well its just like a 17x7.5 +45 rim. You are going to need atleast a 3mm spacer in the rear.
Old May 8, 2012, 10:07 AM
  #292
how about the front? only the back?
Old May 8, 2012, 01:03 PM
  #293
nc_bboy's Avatar
Yeah just the rear, the fronts clear fine.
Old May 22, 2012, 07:59 PM
  #294
kapitolralliart's Avatar
Has anybody tried or considered staggered wheels? What would be the pros/cons? Ideal sizes?
Old May 23, 2012, 07:52 PM
  #295
keithislegit's Avatar
Staggered wheels on a FWD would be pointless. It would only be for looks. The staggered look, if you haven't noticed are for cars that are mostly rwd. awd and fwd cars usually stick with the stance, balanced look. By the way guys, I'm gettting now rims until I have enough to do stance work. What's your opinions on Enkei RPM1's?
Old Jul 11, 2012, 11:53 AM
  #296
bakuro117's Avatar
So Im looking to get some aftermarket wheels and I think I found a set that I like. From what I can understand after looking around a bit is that 17x7.5 +35 should fit well without too much trouble. Although I am a total newb when it comes to replacing wheels. So what should I limit myself to on tires? I want to fill the wheel well with minimal gap at the top of the tire and try to make the wheel as flush to the outside of the car as possible. Not into the slammed/massive wheel setup, id like something functional maybe with a bit of camber adjustment. Will the 17x7.5 +35 do this or should I shop for something else?
===EDIT===
Nevermind I found a setup Im gunna use.
Old Jul 18, 2012, 11:24 AM
  #297
tyson90's Avatar
sooo im a noob to the ra /jdm scene.
and im seeing that alot of you guys are running not very wide rims.
im coming from the euro scene and i am used to being slammed and wide, sooo basically what im wondering is if there is anyway i can fit 8s and 9s on the ra with minimal pulling
Old Jul 18, 2012, 12:37 PM
  #298
EvoM Super Moderator
lanzerralliart's Avatar
With minimum pulling no, with pulling and cutting yes.
Old Jul 18, 2012, 02:36 PM
  #299
Our Ra's don't have wide bodies like our older brothers; the Evo. You'd have to do some major body work to get anything like a 9" on. Although I think K3lv is running 17x9's. I'm not sure. You'd have to ask him personally what he did to get them to fit.
Old Jul 18, 2012, 03:36 PM
  #300
k3lv's Avatar
tyson you're from van?
I ran 17x9 +15 with pulled fenders, but they were pulled hard. I also ran 17x9.5 +10, which is my current setup. The fenders literally beat to **** and aggressively pulled. Going with a different setup instead of stretch tires now. Its no fun driving around in those
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
