Aug 11, 2009, 05:55 PM
Personal Sales Rating: ( 0)
2004 Mitsubishi Lancer
Drives: 2004 Mitsubishi Lancer Ralliart
Emergency Suspension Install Q
I am in the middle of installing some new KYB struts and S Tech springs on my 04 Ralliart and we ran into something we didnt expect. The stock strut is removed, the spring is compressed, and we are trying to remove the center bolt from the top.. but when we try to turn the bolt the entire piston rotates with it. Holding it did not work, a vice grip did not work, even gorilla gluing a rubber pad to the shaft and holding with a vice grip did not keep the entire piston from turning with the bolt. Any ideas on getting this bolt off?
Offline
Aug 11, 2009, 06:01 PM
Personal Sales Rating: ( 3)
Drives: your sister to work in the morning after a long night at my house
weld a peice of scrap steel like some rebar or some small rod to the SOB grab on both sides loosen the nut
Offline
Aug 11, 2009, 06:03 PM
othere wise compress the heck out of the spring have a buddy push down on the top and cut the nut off
Offline
Aug 11, 2009, 06:04 PM
both will ruin the stuts but will get you the peice you need
Offline
Aug 11, 2009, 06:26 PM
hey, thanks for the quick feedback. We tried pushing the top down, but the piece there is held in place (stuck b/w the bolt and the lip at the top of the piston). We had the idea to weld something on too, but dont have the tools, and it is too late in the day to find somewhere to have it done. I guess it's off to the shop in the morning.
thanks again for the ideas
Offline
Aug 11, 2009, 10:18 PM
Drives: 2005 Lancer OZ Rally
If you're using an impact to take the nut off, tapping the trigger will help to break it loose. Everytime I've changed mine around that's happened (or just about) and that technique has always worked.
Offline
Aug 12, 2009, 05:37 AM
Personal Sales Rating: ( 2)
Drives: '04 Lancer Ralliart, '82 Honda Nighthawk, '82 Suzuki GS1100, '81 Suzuki GS1100, '74 Volkswagen Bus
Impact has worked for me every time.
Offline
Aug 12, 2009, 06:30 AM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Yup, impact is the best way. If you don't have air tools, your local tire place can zip them off for you in no time.
Online
Aug 20, 2009, 02:11 PM
Just to to give some closure.. impact worked perfectly and rest of the install went about as smooth as it could. Thanks again to all who gave advice
Offline
Aug 20, 2009, 02:38 PM
Personal Sales Rating: ( 7)
Drives: 05 R/A
time for PICS
Offline
Aug 20, 2009, 09:53 PM
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
