The widest I have run is a 17x7.0 with a 42 offset. Depending on your tire size you may or my not need to roll and run spacers... In my opinion stick with a 7.0 width rim... I ran a 225/45/17 on my 17x7.0 and had to roll the back, and even still they rubbed on the bumper-to-quarter panel mounting point with certain tires. A 215/45/17 would be perfect for a 17x7 tire...Its not worth the hassle to run a wide tire like that. The 225/45/17 that I found to fit the rear well without rubbing was a Falken Ziex 512
EDIT: it was a 42 offset...
__________________
New to the Ralliart forum? Got some questions about your car and its compatibility? Check out the Noob Thread and you'll find a lot of your answer there!
