Mar 22, 2009, 02:11 PM
Personal Sales Rating: ( 0)
2004 Mitsubishi Lancer
Drives: 2004 Mitsubishi Lancer Ralliart
Shake and Brake
Hey guys, Ive got a used 2004 Lancer RA with about 84,000 miles on it. I was hoping some of you might have either experience or ideas as to what is causing my current problem.. Also, hope this is posted in the right section. Please let me know if not and I will get it moved to the correct area.
When I am going over 30mph and start to brake my car starts shaking, rather violently. It is at its worst in the high 30s to 60mph.
My brakes are new and I have had the rotors checked for warping, not the problem. I also just had my alignment done and everything balanced.
The tie rods were replaced about 3 months ago when I first took it in for this problem. It helped for a little while but the shaking has returned since.
At low speeds there is no shaking at all, and I have also noticed that when I really lay on the brakes it calms it down a bit. Medium braking is where it is the worst.
I dont know if it is related but there is a fairly loud squeaking coming from the back, slightly right area, under the hood. It seems to be coming from lower down, transmission? I can't hear this inside the car unless Im stopped and the windows are down.
But I CAN hear a ticking when I am on the gas... it disappears as soon as I push in the clutch. (this might be an exhaust leak, though only last week I had everything replaced with RRM header & dp and magnaflow parts) It can't be heard when left at idle and I get underneath to listen.
I can't think of anything else atm.. but will post more as it comes up. Id really love some idea of what could be going on before I take it in as my experience level is not very high.
Thanks for any help!
Offline
Mar 22, 2009, 02:20 PM
Drives: 2006 RA Lancer
i had similar problem, turn out i had warped the front(factory) brakes, had them machined and all is fine, but you said you had them checked, maybe get a second opinion?
__________________
Quote:
Originally Posted by Lancer7
Fake titties are like driving an ES with an Evo body kit. They look good till you put your junk in the trunk and find out they don't go anywhere.
Quote:
Originally Posted by CleverUserName
you'll pull dudes all day in an evo, whether you want to or not.
Offline
Mar 22, 2009, 03:57 PM
Drives: 2005 Ralliart
How can you tell if you've warped the brakes? I'm having this same exact problem with my 04 RA.
Offline
Mar 22, 2009, 08:35 PM
how mine was it was when i would drive from 60km/h and above and under medium braking the steering wheel would shudder
__________________
Offline
Mar 23, 2009, 09:08 AM
Personal Sales Rating: ( 3)
Drives: dodging potholes at an area near you
If it only happens when you hit the brakes, the problem is obviously in the brake system. Go get a second opinion (maybe someone didnt install averything correctly or something) and while youre at it check the bushings for cracks, etc. as they can be the ones that make weird sounds as the car moves.
__________________
Quote:
Originally Posted by BLKRalliArt04
Man, my gf said she wasnt gonna get me anything for my car, says buying stuff for cars is stupid.
Quote:
Originally Posted by Myszkewicz
I got myself the RRM Piggyback for Xmas. Buying stuff for girlfriends is stupid. :lol:
04 R/A
PR = MIVEC Nation!!
Offline
Mar 23, 2009, 11:29 AM
I figured out that the squeaking and ticking are the same... it just sounds completely different when inside the car. I've also found that braking on an incline sometimes causes a screech like sound in the steering column (doesn't last for too long).
Everywhere I've checked up on this problem I find more on warped rotors, but since the brakes aren't even a year old and I don't drive it that hard I feel like it should be something else.
I will definitely get a second opinion though, and thanks for the comments.
Offline
Mar 23, 2009, 09:25 PM
Drives: mitsubishi lancer ralliart cool silver 04
You can do one of two things, take the rotors to a shop or auto parts store and have them turn your rotors. I don't know how you had them checked but someone looking at them wont be able to tell, and using a micrometer to check thickness wont work, they have to be put on a break machine and turned. I have the same problem, but i am replacing my front calipers ect soooo i went and got new rotors ect. You don't have to drive your car a lot to get them to warp, heck if you drive your car and then hit a car wash, just the simple fact that there metal and you hit them with cold water will cause warping. Rotors can also get hot spots ect, sorry for just rambling on, but your best bet is to spend around 20 dollars and have your rotors turned and see if that does not solve your problem. EVERY TIME you change break pads you should get the rotors turned, sooo the pads have a fresh surface to start on. IF you didnt get them turned when you did your pads then your pads could not be making complete contact with your rotors. Pads create groves in the rotors, sooooo your pads are not making full contact with the rotor sooo basically when your not hitting on the breaks hard your not getting enough contact to slow you down like you would with a fresh turned rotor.
Offline
Mar 24, 2009, 01:42 AM
Drives: 05 RA
check your wheel bearings. jack up the front of the car and give the tire a good shake left and right and up and down, if there is play it's your wheel bearing. also check ball joints and strut mounts
Offline
Mar 24, 2009, 02:20 AM
^^^^^^^^^ good point, yea could be wheel bearing to, lol i was just coming off a 24 hour duty day sooooo didnt think of that.
Offline
Mar 24, 2009, 03:12 AM
thanks for the advice! i will do that, just as soon as all of this flippin' snow clears and I can even make it from my front door to the car.
Im fairly new to the forums and I gotta say.. the few times I've posted or commented I've been really impressed with how quickly everyone responds and how relative the information is  Im glad I got the car that I did
Offline
Mar 24, 2009, 08:10 AM
Personal Sales Rating: ( 5)
Drives: 05 Pearl White Ralliart AT
It just shows how addicted some people are to these forums
haha at least we have an awesome community with a bunch of knowledge about almost anything you can think of with this car
Online
Mar 24, 2009, 11:56 AM
Drives: 05 RA
haha yep yep, welcome to the forums!
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
