Mar 12, 2009, 02:22 PM
Personal Sales Rating: ( 2)
Drives: Evolution 2006
Help in tires upgrade
Hello!
I have a Lancer Ralliart 2006  , I'm thinking in modify the front fenders and rear fenders to can use tires 245-40-r18 because I would like to install G-force 18x9 wheells, what do you think? this modification could works? could I have problems to use 245 tires?
Thanks!
Offline
Mar 12, 2009, 05:57 PM
Personal Sales Rating: ( 10)
2009 Toyota Tacoma My Garage
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Um, there's no chance in hell you're going to fit a 245 tire on the Ralliart, unless you plan on cutting your fenders off and putting on flares. Simply rolling/pulling them won't be nearly enough.
Offline
Mar 12, 2009, 06:03 PM
I know, but I mean I could do a body modification and create a new fenders more big to put that tires  , like the EVO fenders.
That could works?
I have seen in EVOS, with modified fenders tires about 275-40-18 and works correctly, this could be similar? or not?
Offline
Mar 13, 2009, 09:42 AM
Personal Sales Rating: ( 4)
Drives: Lancer Ralliart 2006
I wouldn't go for a mod like this ...
but that's juste me !
Offline
Mar 13, 2009, 12:40 PM
Quote:
That could works?
Hell, with enough modification, you could run 36" drag slicks, but that doesn't make it a good idea. If you really think it's worth it to replace everything you'd have to replace to run evo fenders (you'd basically have to swap in nearly every Evo body panel - rear quarter panel, tail lights, rear bumper, trunk, front fenders, headlights, hood, front control arms, possibly rear control arms) then yeah, it can be done, but that doesn't make it a smart move.
Offline
Mar 13, 2009, 01:04 PM
Personal Sales Rating: ( 29)
Drives: 2005 Mr. Evo Eight
Plus that setup would be too heavy in my opinion. Yes the rims look nice, no its not worth the money. Plus I don't even know if 18's with 245/40 would allow you to even turn the wheel without using an insane amount of spacers.
__________________
New to the Ralliart forum? Got some questions about your car and its compatibility? Check out the Noob Thread and you'll find a lot of your answer there!
Offline
Mar 13, 2009, 03:01 PM
Ohh I see, sounds like a too much work, I have seen in car domain
a Lancer 2002 transformed in EVO 8, but the rims I think are like 16":
http://www.cardomain.com/ride/3049329
This is a Japan Lancer, I think the owner get very easy all parts in a good price,
maybe mitsubishi  parts are available in a little store, jejejee
Then I have to change to the EVO look to can use these rims...
Offline
Mar 13, 2009, 04:51 PM
The easiest way to do it is to do what some autocrossers do to their cheap track cars - cut off the stock fender and rivet on a set flares. It'll look like ****, but if you want a fast way to get a wider tire for racing, that's the way to do it.
Offline
Mar 14, 2009, 05:42 PM
Ok, thanks a lot for yout comments, I will let you know how I fixed this problem
and I will put some pictures
Offline
Mar 15, 2009, 07:38 PM
Personal Sales Rating: ( 1)
Drives: 2006 Lancer RA
Getting coilovers can help too.... waiting for my set, but with some measuring, I figure 225 maybe 235 will be possible (still 16''.... but would like 15''  )
Offline
Mar 15, 2009, 08:04 PM
225 can be done with rolling, but 235 would probably be pushing your luck.
Offline
Mar 15, 2009, 09:31 PM
I will buy Megan Racing coilovers, because checking, I need to use 245-35-r18
and not 245-40-r18, and using the stock coilovers the car will see maybe good, but I will feel all  , I have a friend that has a body shop, and he will help me
with the fenders modification
But I'm thinking about if I could have problems with the offset, I want to install
Rota G-force rims 18x9 +30mm, I'm not sure if I will have problems with the calipers
Offline
Mar 15, 2009, 11:29 PM
I would do a 245/30 instead, with as wide as you want to go, I'd err towards a smaller tire. Also, you won't need to worry about clearing calipers.
Offline
Mar 16, 2009, 06:43 AM
Personal Sales Rating: ( 0)
Drives: Lancer Ralliart 06
with that much grip and weight, your car will feel slow as hell on startup and acceleration
This will decimate all after you put 15k or more, import parts for Japan if we need to.
Offline
Mar 17, 2009, 03:26 PM
Ohh sounds very bad, then this upgrade could affect much to the performance of
my Ralliart?
I think the Rota rims are not heavy.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
