Go Back   evolutionm.net > Lancer Ralliart Forums > 04-06 Ralliart Tires/Wheels/Brakes/Suspension
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Mar 1, 2009, 09:14 AM   #1
Personal Sales Rating: (0)
ElectricBlueEvo's Avatar
Drives: 2005 Evolution VIII
Cusco Type II Lower Brace
Any thoughts on the Cusco Type II lower brace? Does it fit (I have stock dp)? Do you have to remove or modify the plastic lower panel? Can you feel the difference on the street. T.I.A.
__________________
"Too soon old, too late smart"
Offline
Old Mar 1, 2009, 09:35 AM   #2
EvoM Super Moderator
Personal Sales Rating: (10)
2009 Toyota Tacoma
My Garage
otter's Avatar
Drives: 09 Not An Evo; 04 Not An Evo; 96 Not An Evo (destroyed)
Send a message via AIM to otter
Are you asking this about an Evo or Ralliart? It'll fit both, and IIRC, it attaches far back enough that it doesn't interfere with the undertrays.
__________________
READ EVERYTHING IN THIS LINK BEFORE PM'ING ME ABOUT WHY YOU CAN'T POST IN THE CLASSIFIEDS!!!
Problem with a post or thread? Use the report post button, it's faster than PM'ing a single Mod.
Read and obey the rules to help keep this forum a great place!
My Ralliart
Michigan Evo/Lancer club
Online
Old Mar 1, 2009, 09:51 AM   #3
TS8
Personal Sales Rating: (14)
Drives: 03 EVO8
It'll fit with no problems, as mentioned above.
As far as feel, the more you modify the suspension (lowering spring, higher spring rates, stiffer struts and coilovers), the more you can tell the difference.
Also, I drive here in the pothole Capitol of New York city, where I can definitely
feel more solidity in the front end. (Bilstein w/ Swift spring upgraded)
I guess the best brace would be the 6point Mine's or Carbing brace (around $250), but I got a used Cusco type 2 for $80 used.
Installed it about 3 months ago on my almost 6yr old - 67K Evo, and it was definitely worth the money. My stock brace was slightly bent form hitting something, I noticed it during install.
I'm sure if you get it with the Type 1 at the same time, it will obviously tighten the front end even more. If you are going to modify your suspension, I think its worth it!
Offline
Old Mar 1, 2009, 05:18 PM   #4
Personal Sales Rating: (13)
Evodreamer28's Avatar
Drives: TurboEs
Send a message via AIM to Evodreamer28
Yes it should fit with the stock downpipe and plastic if im not mistaken. Check out Speed Corps they have the Type 1 & 2 for a really good price!!! They also carry the full line of cusco power braces which can be found here.....
http://stores.speedcorps.com/-strse-...Categories.bok
Type 1
http://stores.speedcorps.com/-strse-...Evo/Detail.bok
Type 2
__________________
"In The Eyes Of A Blind Man, You Can See Everything"
Offline
Old Mar 7, 2009, 01:11 PM   #5
Personal Sales Rating: (1)
Maximum404's Avatar
Drives: '06 GG EVO MR
Send a message via AIM to Maximum404
Anyone know if this fits the Megan TBE? Also, best prices can be found from JSC that I have seen. Much cheaper than Speed Corps (pretty high prices).
__________________
Max S.
'06 GG EVO MR
WPI '06
Offline
Old Mar 10, 2009, 08:54 PM   #6
Drives: Mitsubishi Evo 9
This bar will fit on a stock dp. No modification is needed.
Aftermarket DP you might need to worry but stock should be fine.
Type 1 and 2 fits perfect on my Evo9.
You cant feel a huge difference unless you upgrade alot of your suspension.
Offline
Old Mar 14, 2009, 02:24 AM   #7
MivecLancer1's Avatar
Drives: ralliart lancer
I know that evo bars fit the ralliart, well at least the cusco type 1 and 2 as well as the megan h brace. My experience with the megan bar has not been too good. After the bar was installed I was hearing popping noises from my front right lower suspension. I believe this is a result of having too much stiffness due to my sway bar links and bushings. The car does behave a little better with the bar but if anyone has experienced this type of problem please chime in as I have since removed the bar to save my ears.
Offline
Tags
bar, brace, braces, cusco, evo, front, ii, ix, lower, member, mr, pa, suspension, type, ver, version
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
